Old 02-04-2007, 12:06 AM   #1
crm318
Alright Alright Alright
crm318's Avatar
wobbly harmonic balancer
i currently built a 350 and started it for the first time yesterday. it ran like crap. i assumed it was because the timing was way off and i need to break in the cam. today. i tried to let it idle, but it ran rough and i heard i slight rattling/knocking. when i was putting the timing light on it i noticed that the harmonic balancer was wobbling and almost hitting the power steering pump bracket. i took a closer look and the inner part was perfeclty centered and the outter part was the part wobbling. also it looked like the pully was slightly off to. do you think that the 15 min of 2000-2500 rpm cam break in could have messed up my engine? the timing mark didnt even show up on the balancer with the light on it. what do yall think? and yes, i will getting a new balancer.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 02-04-2007, 12:10 AM   #2
Skip Greaney
Junior Member
Skip Greaney's Avatar
Re: wobbly harmonic balancer
If it is a stock balancer it probably has seperated at the rubber absorber. Happens alot from wear strain or a component drag, and alot of people put them on with a block of wood and a hammer instead of using an installer. Get a new one or a aftermarket if the engine is producing over 400 HP!
Skip Greaney is offline   Reply With Quote
Old 02-04-2007, 09:13 AM   #3
jbon64
jbon64's Avatar
if you suspect it shifted you could do the normal #1 piston top dead center , then see if the timing mark is lined up .
hey.....smell my finger
64 nova wagon , 63 nova convertible
jbon64 is offline   Reply With Quote
Old 02-04-2007, 09:27 AM   #4
cooters
the balancer wont cause the motor to run like crap, you shouldnt have done bearing damage to the motor in 15 min. Check the key way on the crank to ensure it is good and ALWAYS use a balancer installer
cooters is offline   Reply With Quote
Old 02-04-2007, 10:05 AM   #5
truckdude239
truckdude239's Avatar
if the breaking period is not done right about 15-20 mins at 2000 rpm you can mess a cam up fast (ie lopes wore off)
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-04-2007, 01:02 PM   #6
crm318
crm318's Avatar
yea, i know that the balancer wont cause the motor to run bad. i just saw that the outter part was trashed along with the rubber and i couldnt find that timing mark because of it. im going to get a new balancer. i havent been able to find a cheap one. they go for about 50-60 at the local parts store.
1972 Cheyenne
Old 02-04-2007, 03:23 PM   #7
cooters
50 to 60 for a new balancer is well worth the money. I never use old ones. This problem is why i say you cannot use a timing light on a stock balancer because the marks rarely are in the right place.
