Flat Black, & Chrome!
Rear End Id, Tranny Id?
My truck is a 1983 Chevy Scottsdale Stepside, the person I bought it from said that the motor is a newer 350 crate with about 5k miles on it, does it look like a crate engine? I need to find out what kind of read end/the gear ratio I have in this truck, can anyone tell? and the tranny, I'm thinking TH-700, am I correct? Its automatic.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by Rc 415; 02-04-2007 at 06:32 PM. |
The Crazy Machanic
Re: Rear End Id, Tranny Id?
i think it a 700r4 caus of the square pan for the rear ration i dont know what the code mean but i think it might be on the driver door two
Thanks, I'll check the door tomorow!
Stepsides RULE
The options code indicated a TH700R4... the sticker on the side of the motor tells me it is indeed a crate motor (unless he's REALLY a crook and slapped that sticker on the side of the motor
![]() Hope that helped.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
#5 | |
Stepsides RULE
Yes, the 5.0 is 305 cubic inches, 350 is 5.7. Its ok, my dad didn't know my truck had caution flashers and he bought it new in 1980...
Sb 400 club
It looks to be the base stick replacement 350 5.7 liter. i think it is a 290 hp??? It definatly looks to be a crate judging by the sticers but it does look kinda dirty to have 5,000. Then again every body cleans diffrent things. 10 bolt rear with 700r4 od trans. Wish i could help on the rear ratio
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Thanks guys now all i gotta do is figure out the gear ratio!
You get what you pay for
![]() Join Date: Dec 1999
If you will look on the passenger side axle tube, about 3 - 6 inches out from the center section on the front side, there will be a 3 letter/number code, hand die punched into the tube. You will need to clean it real good because they are extremely hard to find being as they are only around 1/8" tall. Find this code and I will tell you what ratio your truck came stock with.
Mike 1985 Chevy C-10 |
Insert Witty Text Here
The sticker on your engine looks just like the one on my crate engine. I would say it probably is one unless the PO just used the valve covers off of one. Mine is the 260 hp cheapo crate engine, but the 290 hp 350 probably uses the same stickers.
Slonaker |
I'm pretty confident that its a crate, here are a few other crappy pics:
While we are on the subect of the engine, I want to get a dress up kit, specifically this one:
http://www.jegs.com/webapp/wcs/store...59725_-1_11357 but I am wondering what would happen to the hoses and stuff that plugs into the current air cleaner? Also that aluminum flex hose you see coming form the manifold to the air cleaner? |
Stepsides RULE
All that stuff is emissions and can be eliminated / relocated (unless your local area inspects emissions items closely). Your kit there includes the breather cap for the valve cover, which eliminates the crank case breather hose that plugs into the air cleaner. Another one of those hoses is for the vacuum switch in the air cleaner, so it will be eliminated if you went with an aftermarket air cleaner such as the one in that kit. That alluminum hose is the pre-heater hose, warms the air going into the carburetor to help cold weather warmup. You can do without it.
Hope that helps.
#15 |
From what I remember, rear axle standard is a 2.73, way to high geared for the 700.
98 Neon 97 Grand Prix GT 02 Grand Prix 40th Anniv. 86 GMC 5.0 77 Olds 98 6.6 REAL AMERICANS, DRIVE AMERICAN |
#16 |
But they are both stock right? Why would Gm do that?
#17 |
![]() Join Date: Apr 2005
What about it being a 3.08? I just removed the smog crap off my engine. Boy did it wake the motor up. I'm happy we have no smog police, as of now. Headers next fellas.
#18 |
thanks guys!
#19 |
TUM is a 2.73 ratio. Standard rear axle only means what GM considered standard for each year, or something close to that anyway. Somebody explained this before in great detail. I just can't remember who it was. 2.73 was standard in 85 also.
On another subject, have you thought about reducing the size of your photos. A lot of folks on here are on dialup and it kills them to open threads like this one. |
#20 |
www.73-87chevytrucks.com
I believe it was 73-87 Dictionary KIILew. I forgot you had the axle codes Mike...
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#21 |
Hey sorry about the pics, I'll resize them for forums when I get home!
#22 |
Yeah, my 85 came stock with 2.73 gears and a 700-R4 tranny. 86k10 is correct, the gears are way too high for an overdrive tranny. I have 3.73 gears in mine now and I'm way happier.
As for why GM does stuff, who knows. They sure don't have any logical reason I can think of. It was a gas mileage reason I'm guessing but what they didn't take into consideration is overdrive. With the high gears it would always unlock and drop down into a lower gear, especially going up hills. A lower rear gear would keep it locked into overdrive and thus save on gas in the long run. |
#23 |
You're right Chis, it was Ken, our 73-87 know it all.
![]() Yes, I've got the numbers for all the years. |
