02-04-2007, 08:21 PM | #1 |
Junior Member
carb rebuilding
reassembly phase of rebuilding my qjet, and i finally ran into a problem. midway thru reassembly, i realized that the fuel discharge ball never came out. upon inspection as to why, its because there is a little ring of rust holding the bastard in!
what on earth do i do to get it out?? |
02-04-2007, 08:26 PM | #2 |
Re: carb rebuilding
compressed air
02-04-2007, 08:50 PM | #3 |
laying low
Re: carb rebuilding
Little hit of wd 40, let it sit and blow it out with air. Keep your eyes on that little ball though, through safety goggles that is.
02-04-2007, 10:18 PM | #4 |
Re: carb rebuilding
a needle held with needle nose plyers to scrape the rust away after letting it set overnight with wd40
02-04-2007, 08:48 PM | #5 |
Junior Member
Re: carb rebuilding
ohhhhhhhhhhhh yeah, i guess that makes sense. i guess ill take it with me to work tomorrow, and stop off at the goodyear and see if the fellas there might blow it out for me.
02-05-2007, 11:58 AM | #6 |
Junior Member
Re: carb rebuilding
well that ball blew right out on the first shot! whew! i was getting a little worried that i was going to be buying a new carb over a tiny rusted metal ball!
hopefully today ill have time to finish the reassembly, and try it out on the truck! |
02-05-2007, 10:24 PM | #7 |
Junior Member
Re: carb rebuilding
SHE RUNS!!!!
i just put the carb back on, and she fired up on the first crank!!! im astounded that i rebuild a qjet on my first try, but i feel like ive passed a litmus test, and i DO have what it takes to restore a vehicle! now i just need to figure out how to smooth her out, and ill be able to drive around a bit. i had some trouble with the secondaries intake flaps, but i found a carb shop about 3 miles from my apt, and they had a ton of qjets laying around. they wernt really in the spare parts business, but i talked the guy out of a spring-return for the secondaries, for $5 (i needed it, and i wanted to make sure i left with it!). i actually had it on and running earlier today, but with the secondaries stuck open. it would fire, but would only run wide open and then die when i let off. now, it starts and almost idles, but then dies. i need to so some reading on what to do with the mixtures, and then im set! |
02-05-2007, 10:30 PM | #8 |
In Memoriam...
Re: carb rebuilding
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
02-05-2007, 10:46 PM | #9 |
Junior Member
Re: carb rebuilding
thats EXACTLY the way i feel right now!! i celebrated by running down to the autoparts store and picking up a chrome 14" air cleaner
02-07-2007, 09:45 PM | #10 |
Junior Member
Re: carb rebuilding
just had me another parking lot celebration, because i got her tuned close enough to roll without dying!!!
02-05-2007, 10:37 PM | #11 |
Re: carb rebuilding
plus check the play in the throttle shafts........they are vacumm leaks when they are worn
02-05-2007, 10:40 PM | #12 |
River life......
Re: carb rebuilding
Nice, it definitely feels good to make some headway.
