are theses the headers to use on baged trucks
need help picking the exact header for my truck with airbags. right now i have the hooker comps fit great but i think its going to cause problems with the way i run my exhaust. searched on the site and alot of people using the headers for camaros, but i couldn't find that many pictures or part numbers. can you guys tell me if these will do the trick http://store.summitracing.com/partde...5&autoview=sku
Re: are theses the headers to use on baged trucks
I plan to run the 3/4 length headers from Skip White on ebay. They are for 88-95 trucks, but they fit with a little trimming on the driver side and you have to plug the O2 bung. They are only $160 and they are ceramic coated, not a bad deal.
I was told a Camaro headers don't fit because they hit the motor mount on the driver side.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
I was told a Camaro headers don't fit because they hit the motor mount on the driver side.[/QUOTE]
what headers will fit. |
Active Member
I'm running the camaro headers on 71 2wd. No problems with hitting motor mounts, but did have to trim about 1/8 -1/4 of an inch of upper frame rail on passenger side......no big deal!! For pics and part number go here
http://67-72chevytrucks.com/vboard/s...d.php?t=166291
1971 SWB SOLD
I first tried some shorty headers out of a firebird and the drivers side hit the a-arm.
71' Chevrolet -> 350c.i. w/ 600 Edelbrock Carb, Headers, P/S, 3/5 Drop |
I have 3/4 length headers for a Chevelle/Malibu ... they don't rub anywhere.
maybe i missed something, but why not use the shorties designed for our trucks, as they are readily available...
I know both hooker and heddman have them ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill Last edited by brak; 02-08-2007 at 11:20 PM. |
senior member
how low are you going to be to need these headers? im bagging my truck with stock spindles and no nothc think ill be ok?
69 GMC bagged |
the hooker comps i have now hang down about three inches and since i'm putting in a new tranny crossmember and a new drop center crossmember i want to run the exhaust between the frame rails. i have it bagged with the drop spindles and the headers aren't that bad the only time it hits is when its aired down all the way. but i can take better advantage of the new crossmembers with new shorty headers or 3/4 headers just need to figure out which ones.
