02-08-2007, 12:16 PM | #1 |
Sierra Grande Club
Electric choke for the factory Q-jet?
I’m looking at getting an air gap intake which doesn’t have the divorced choke.
Is there anything I can do short of getting a new carb? Electric choke maybe? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
02-08-2007, 01:07 PM | #2 |
GEARHEAD
Re: Electric choke for the factory Q-jet?
TRY here, Not sure if this is what your looking for. if not an electric or manual choke should fix you up. I love the Air gap too.
http://www.carburetion.com/quadrajet.asp |
02-08-2007, 01:29 PM | #3 |
Sierra Grande Club
That’s cool; I’ll give them a call. I also might need some jetting too.
s/t
02-08-2007, 02:23 PM | #4 |
Sierra Grande Club
That eclectric choke mounts in the same spot the orginal one does. I'm going to need something that mounts to the carb.
02-08-2007, 02:36 PM | #5 |
blood type; Retumbo
do you really need a choke in your area?
look at a Qjet from the mid to late 70s and rob the whole assembly from it. |
02-08-2007, 02:56 PM | #6 |
Sierra Grande Club
will this work? Sounds good.
02-08-2007, 03:26 PM | #7 |
what is the solenoid looking thing-a-ma-jig that the throttle rest on on the right side of a quad? what does the wire hook to? to me it looks like something to idle the motor up with while the a/c is running?
1972 C-10 SWB 350CI TURBO 350 TRANNY, TILT, POWER WINDOW & BRAKES, TANK UNDER THE BED W/MARKER LIGHT FILLER. 3.08 GEARS, CLASSIC AIR :hit2: :hit2: 4 WHEEL DISK BRAKES 2000 chevy blazer 1990 nissan pick-up 1984 mazda pick-up (son's project truck) |
02-08-2007, 04:19 PM | #8 |
the early qjets cannot have elecric chokes put on but the mid 70s qjets just need the electric chock installed in the bimetalic housing on the carb
02-08-2007, 04:59 PM | #9 |
its all about the +6 inches
I don't know jack about quadrajets... however, I DO know that they caddy big blocks had electric chokes on them.
02-08-2007, 09:27 PM | #10 | |
Sierra Grande Club
Dean
02-08-2007, 10:08 PM | #11 |
This is what your looking for
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
02-09-2007, 12:02 AM | #12 |
tha caddy qjets and olds have the fuel line straight out the front instead of the side. Pick a late 70s q jet, i believe the US qjets went to electronic metering around 81, in Canada ours did not change till 86
02-09-2007, 08:28 AM | #13 |
blood type; Retumbo
EXACTLY!!!!!!
look for a 75ish (pre- aneroid) from a light truck or large car. stay with one from a small block, biger engine carbs have a richer fuel curve which is very difficult to make work correctly for your truck. what i am running is a stock one from a 79 G20 van (engine donor) that I re-calibrated to 72 truck SBC specs. I drilled out the air bleeds and swapped all 4 jets and rods. with mine you can change the lean limit while the engine is running for fine tuning. the older ones you have to remove the carb because the screw is behind a plug on the front of the base plate making access almost impossible. |
02-09-2007, 04:58 AM | #14 |
Saving 1 truck at a time!
Most Qjets from 1975 on had the choke mounted on the carb. I have a 1976 454 with the divorced choke however. The model 4MC (carb mounted thermostatic choke) and 4ME (carb mounted electric choke) are the models you are looking for. The 4MV is the divorced choke model.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
02-09-2007, 06:38 AM | #15 |
Well,since these trucks started coming with automatic choke in 69 or 70,Any original carb from that year or newer.Your carb must have been swapped.
02-09-2007, 09:14 AM | #16 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 02-09-2007 at 09:17 AM. |
02-09-2007, 09:37 AM | #17 |
I have not seen qjets with a choke on the carb until the mid 70s. The early qjets had a few holes for a vent right on top of the carb above the fuel filter housing, you need a carb with the choke housing on the carb.
02-09-2007, 12:03 PM | #18 |
Sierra Grande Club
So what gets hooked the electric choke? 12v on a keyed source or thermal sensor?
02-09-2007, 05:31 PM | #19 |
12V keyed, also take a picture of your carbs linkage with you when you go looking. That carb is off a mid 70's Caddy (795CFM, side fuel inlet) the base plate will need to be changed to one with the right linkage setup or dissembled and put in a throttle shaft with the proper linkage.
