Has anyone ever chopped a top 1 inch?
I want to lower the top but dont want it to look like a chopped truck. No offense to the chopped trucks because they look cool too. Any pictures out there?
"I told my dad I stopped raisin hell, and he called me a quitter" www.fergenboysinc.com |
![]() Join Date: Mar 2004
Re: Has anyone ever chopped a top 1 inch?
no one in there right mind would chop a roof 1 in. there are many reasons for this but the big one is you really can't tell it's been chopped 1 inch. the smallest chop is usualy 3 inches because it's enough to be noticable but still maintain head room. i have heard of less but thats usualy on larger cars and it's usualy for a wedge chop. i.e. 3in in front 1in in back.
chopping a top is alot more than just cutting the top. you also have to think about custom windsheild, choping the doors, many times you have to widen the roof to make it fit, exc. it's alot of work and it might be worth it to farm it out if your not great with body work. ondrew |
#3 | |
Fabricate till you "puke"
I chopped mine 4, but I have seen a couple that were around 2" on the chop that looked really sweet. My opinion (everyones different), is that these trucks take to a 2-4" chop very nicely. I doubt that I would go through the work for just 1" off the top tho....2 maybe works tho
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
This one has a mild angle chop I think it's something like a 2 inch. The truck belongs to a board member so someone may have more detailed info if it is close to the look you want.
72 SWB parts and pieces Oklahoma |
One more time.
![]() Join Date: Jan 2005
Check with chopped 71, he has a sweet one. And the front and rear windows were critical.
68 Short Stepside C-10 69 SWB C-10 70 Flatbed C-20 70 LWB C-20 BB402 70 LWB C-10 CST 70 LWB C-10 CST 71 Short Stepside Cheyenne C-10 72 LWB C-10 72 Blazer 4x4 4spd 95 Jeep Cherokee 4x4 |
couldnt find any pictures?
In Memoriam...
It gives a GREAT look...very subtle effect when you only go 2", but MAN that's a bunch o' work. That's probably why most chop tops I've seen have a more dramatic look, ie. 4"-5", which imho is too much. 1" would probably not even be noticed, much to your dismay. Only you would know it's there.
Also, I think the chops look a little better when they are slightly raked forward, rather than being completely level. Gives it a bit more racy, aggro look.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
oh my god stroker, is that your ride? That truck is sweet
I WISH !!!!!!!!!!!!!!!!!!
I agree it's a nice one and possibly the coolest part of the truck is under the hood.
Epoxy Primer Friendly
A 2" chop to level the rear and side windows looks perfect.
