02-10-2007, 10:42 PM | #1 |
Firefighter
Distributor Position
If the distributor is installed 180 degrees out will the engine still run?
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
02-10-2007, 10:49 PM | #2 |
Re: Distributor Position
more popping than anything else
heres every thing you need to know http://67-72chevytrucks.com/vboard/s...d.php?t=225820 |
02-11-2007, 09:21 AM | #3 |
Designated A-hole!
It will run perfectly....if you wire it 180 degrees out.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
02-11-2007, 08:26 PM | #4 |
or in Australia!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-11-2007, 09:32 AM | #5 |
Broken Down
You can just pull you cap and plug wires off and start your firing order from where your Rotor is sitting and just adjust your distributor by twisting it. That is if you do not want to pull it again.. Just my .02
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
02-11-2007, 07:53 PM | #6 |
Fabricate till you "puke"
180 out on the old points distibs.....a quick "git er done" , was cut the square peg off the rotor & turn it 180. square pegs dont fit round holes too easy(not without some screamin anywho ) Hell, if you set that #1 piston tdc (compression stroke), you can dump that dist in any damn way you like......just start # wire where the rotor is pointed(allready mentioned above)....... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
02-11-2007, 08:21 PM | #7 |
Old Duffer
It's not just the dizzy. You are better off to just roll the eng to #1 TDC, turn your dizzy shaft a little past where the rotor would match up with the cap's #1 wire, then lower it into the block and be sure it seats completely flush with the block. Don't forget that the dizzy shaft drives the oil pump! It will only seat correctly or 180 out.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
02-11-2007, 08:30 PM | #8 | |
installing it spin's forward, removing and it spin's backward |
02-11-2007, 08:37 PM | #9 |
Old Duffer
Thasright! Just DO incorporate the oil pump!
