Old 02-12-2007, 09:58 PM   #1
gus67
gus67's Avatar
Manual Choke
Just wondering if you guys changed out the manual choke to automatic choke, on your trucks. Or what is the best thing to do.? Any opinions will help
gus67 is offline   Reply With Quote
Old 02-12-2007, 10:04 PM   #2
rage'nrat638
rage'nrat638's Avatar
Re: Manual Choke
well you can install this kind of hooky set up with a stock carb
http://www.carburetion.com/quadrajet.asp
or you can get a 75 truck carb with a hot tube choke and convert it
rage'nrat638 is offline   Reply With Quote
Old 02-12-2007, 10:06 PM   #3
rage'nrat638
Re: Manual Choke
this is the stock spring box set-up
Old 02-12-2007, 10:07 PM   #4
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Re: Manual Choke
Eventually, when I get the q-jet installed, I am going to go manual choke. The 2-barrel I'm using now has the later style auto choke and it usually works good (2GC). I've had problems with the auto choke that have the coil mounted on the manifold (2GV type); the later kind mounted to the carb works much better. What kind of carb are you using?
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-12-2007, 10:09 PM   #5
gus67
gus67's Avatar
Re: Manual Choke
it's the original single barrel carb that's in their. rochester.
Old 02-12-2007, 10:22 PM   #6
oldgold70c10
Who's got steelies?
Re: Manual Choke
Might have to go to a salvage yard and find a later 1 barrel, say from a mid 70's straight 6 truck.
My Truck Page
My Youtube Channel
Old 02-12-2007, 10:25 PM   #7
gus67
gus67's Avatar
Re: Manual Choke
i'm in california so is manual choke really that necessary, or should i just change it out completely.
Old 02-12-2007, 10:31 PM   #8
oldgold70c10
Who's got steelies?
Re: Manual Choke
If it is annoying to use the manual chike, then I'd say replace it with an auto choke. But if it stays warm enough (shouldn't have to use the choke if it is 60-65 degrees or warmer) and you don't have to use it, then leave it in. Have you been having trouble with the carb and thinking about upgrading?
My Truck Page
My Youtube Channel
Old 02-12-2007, 10:35 PM   #9
gus67
gus67's Avatar
Re: Manual Choke
actually i'm in the process of restoring it, and just wanted to get informaiton ahead of time so I can plan ahead. so might be easier just to rebuild it and leave it as is.
Old 02-12-2007, 10:49 PM   #10
oldgold70c10
Who's got steelies?
Re: Manual Choke
What kind of engine have you? I'm assuming a straight 6 since you've got a 1-barrel.
If you wanted to convert to an auto choke, the easiest thing to do would be to get a mid 70's 1 barrel with the auto choke mechanism mounted to the carb itself. Either way, unless you buy a new carb, you'll probably have to (or want to) do a carb rebuild.
My Truck Page
My Youtube Channel
Old 02-12-2007, 10:47 PM   #11
Shyguy
Junior Member
Shyguy's Avatar
Re: Manual Choke
My son tells me that a well tuned engine does not require a choke, so he does not have one on his 70 C-10 with a 350 and a Holley carb.
I on the other hand have a 71 C-10 with a stock 350 with a quadra-jet and have converted it to a manual choke.
Danny - Southeast Missouri
71 C-10
Pretty much stock except for it has a 70 Camaro 350 engine
Shyguy is offline   Reply With Quote
Old 02-12-2007, 11:44 PM   #12
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: Manual Choke
Personally, I like the direct action and mechanical goodness of a manual choke. Makes me feel as one with my machine.
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 02-13-2007, 02:25 AM   #13
Warren
Re: Manual Choke
dont see how if an engine is tuned well it would not need a choke.
An old racer put a manual choke on mine,. it is just a cheap one 25.00cable a bit more expensive would have been better but it works well and I like the fact that I can kick it down to a number of RPMS, whatever Idle I want and leave it there till I want it off.
Should do the same for my Wallywagon, it races till it is good and ready and can't be kicked down till it is ready. That can be adjusted by putting solder onto one part till you get the right amount of weight then it will kick down sooner. May get the mechanic to do that.
Warren
Warren is offline   Reply With Quote
