Old 02-13-2007, 09:11 PM   #1
Down south truckin
Down south truckin's Avatar
anybody ever seen a gas tank delete???
this is a 1970 1 ton dually i got a while back and was wondering if anyone has ever seen one i assume its factory because on the spid it has a option for cylindric fuel tank.let me know if yall think it is factory i guess next time im near it i should look at the floor and see if it has holes for the lines. thanks Mike
Down south truckin is offline   Reply With Quote
Old 02-13-2007, 09:13 PM   #2
Down south truckin
Re: anybody ever seen a gas tank delete???
forgot the pictures
Old 02-13-2007, 09:16 PM   #3
Down south truckin
maybe this one is less blurry
Old 02-13-2007, 09:24 PM   #4
66skylarkpost
66skylarkpost's Avatar
i parted a very low mileage '69 1ton dualy camper a couple years ago where it had a large tank on the side of the frame and the one in the cab
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car
66skylarkpost is offline   Reply With Quote
Old 02-13-2007, 09:58 PM   #5
Down south truckin
yeah i've seen several with two tanks but only seen 2 that i can remember with no tank in the cab i still own the other one but i believe the fuel neck hole is welded up on the other one anybody else have any info on this? thanks Mike
Old 02-13-2007, 10:58 PM   #6
Skip Greaney
Junior Member
Skip Greaney's Avatar
Part #3997088 was a cover for fuel tank opening...it use to look like that so I am sure it's factory. Was more common on 40 series trucks with stake bed and "saddle tanks". I would say that was it.
Skip
Skip Greaney is offline   Reply With Quote
Old 02-14-2007, 12:18 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
seen plenty on the C/40 and bigger trucks.
Old 02-14-2007, 01:57 AM   #8
BIGJAKE97
BIGJAKE97's Avatar
do you have any idea what "flasher unit" is? it's on the bottom left row of the glove box option list
67 short fleet
71 blazer 4x4
72 blazer 2wd
76 gmc sierra 3/4t 4x4
62 bel air
01 blazer extreme
member 11,943!
BIGJAKE97 is offline   Reply With Quote
Old 02-14-2007, 06:12 AM   #9
Longhorn Man
probably a HD flasher
Old 02-14-2007, 07:10 AM   #10
kenm78
Broken Down
kenm78's Avatar
I plan to weld my closed
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 02-14-2007, 09:06 AM   #11
It`s factory alright.Pretty rare on a 1t.That`s a nice set of options.So,what was that trucks original purpose in life?I see it had a special paint option.What does it look like,that lime-ish green like some emergency equipment use?Very interesting.
Old 02-14-2007, 12:41 PM   #12
Huskerboy2
My '68 motorhome has one, since it has the pass through from the cab into the motorhome. Saddle tanks on either side of the frame. It's not listed on the glovebox though and I'm sure it was done by the motorhome company (Open Road) as part of the conversion. They used a chrome "gas cap" that is permanantly installed in the opening.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 02-14-2007, 12:42 PM   #13
Huskerboy2
That is an interesting list of options. Tell us more.....
'72 Chevy Blazer
Old 02-14-2007, 02:27 PM   #14
Down south truckin
Yeah kinda neat medium green metallic. i dont see any holes or crazy wiring.I got it as a cab and chassis and really dont see any kinda of welding on the frame other than the pieces that level the frame behind the cab, iassume those are the (body cross sil mtn) that is on the spid. the truck is available if anyone wants to add it to there collection cause mines getting to big!thanks Mike
Old 02-14-2007, 09:19 PM   #15
I`m thinking RV.But,why the moved tank since it`s not a pass-thru.Unless it`s for more capacity.
