Harmonic Damper for Goodwrench 350
I am installing a new Goodwrench 350. The harmonic damper off my original 305 is galled in the sealing area so I am going to replace it. Also, the original timing marks on the 305 chain cover are in the 12:00 position which is different than the bolt on timing marks that came with the new 350.
The local NAPA store can get me a new harmonic damper that fits a 77-86 350. LMC also sells a 350 damper for 77-86. Is that the right harmonic damper? I want to make sure the TDC/timing indicator matches correctly with the damper. |
![]() Join Date: Apr 2005
Re: Harmonic Damper for Goodwrench 350
They will work just use the correct timing tab. Your crate engine should have came with two tabs. I've got a adjustable tab, so I'm not sure which one to use. The tab depends on the size of the balancer. I'm sure if you purchase it from NAPA they will sell you the correct tab to work with the balancer.
Right turn Clyde
Hamonic Balancer 8in from Summit Racing # SUM-161358
http://store.summitracing.com/partde...115&rsview=sku Timing tab for 8in balancer from Summit Racing # PRO-141-202 http://store.summitracing.com/partde...rt=PRO-141-202 Prices are resonable but Im not sure about shipping costs.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Thank you very much for the info and yes I have the 2 tabs that came with the new engine.
I bought my 8" balancer from a local GM dealer for like $60.
I have that engine and I used a Pioneer w/ engraved timing marks 6 3/4 " balancer nice quality piece. There are some that say 8" is better .
Mad Scientist
Yep...Pioneer makes a nice balancer for about $60 and a factory balancer is about the same price also. Summit shipping is free, you just pay a handling charge.
![]() 86 1/2ton on tons! sbc/465/208/D60/14/35's 81 Postal....with 468 bbc 97 Merc Marq comuter 07 Suburban 02 Danger Ranger |
