02-16-2007, 11:04 PM | #1 |
Rear Axle CL
On a 59 is the rear axle centerline the center of the bump stop? I'm getting ready to install my 4-link. Also, any opinions on mounting the 4-link on the inside of the frame compared to the outside (will be running a 10" wide wheel)?
02-16-2007, 11:07 PM | #2 |
Re: Rear Axle CL
my 4 link will be inboard...just run really stiff shocks...
02-16-2007, 11:24 PM | #3 |
Hollister Road Co.
Re: Rear Axle CL
The rear end locates 36.5 inches from the rear frame rail ends with all extensions and brackets removed. If you are going to locate it this way you need to make sure your frame is square. Take a look at http://www.webrodder.com/article.php...&SID=60&CID=11
It explains how to check square with inexpensive tools. You can mount outside or inside outside gives you better roll on corners stability. Inside gives you better tire clearence. |
02-17-2007, 08:14 AM | #4 | |
Yellow truck club
Re: Rear Axle CL
I think if the bars go on the outside of the frame your tire is going to hit the box before the bars unless you tub the box. What are you using for springs? With the right back spacing I think the 10" will work ok in the fender. Brian ...
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 02-17-2007 at 08:16 AM. |
02-17-2007, 09:50 PM | #5 |
Hollister Road Co.
Re: Rear Axle CL
I have a tri bar in mine and 13.9" tire section, I could have run a 4 bar outside and still had room
