Old 02-21-2007, 09:24 AM   #1
rlm316
rlm316's Avatar
Info on brake lines for crossmember swap
I was wondering if anyone would have any info on which brakeline set-up they used on a '73-91 3/4t crossmember change. I was planning on using the mastercylinder and booster from a '71 or '72. I would like to use a pre-bent kit. I just bought my rear lines from Inline Tube and they said they did not offer a kit for this popular change. I am thinking about using the line set for the donor truck and making the necessary changes to install. Any help to keep me on the right path would be appreciated. Thanks.
rlm316 is offline   Reply With Quote
Old 02-21-2007, 09:33 AM   #2
cooters
Re: Info on brake lines for crossmember swap
bend your own lines, its easy just takes a little time but in the end you have the lines where you want them
cooters is offline   Reply With Quote
Old 02-21-2007, 10:01 PM   #3
Okie Bucket
I used the lines,prop valve, master and booster from donor truck. The existing brake lines ran behind crossmember and looked difficult to hook up to caliper hoses and use factory brackets to hold hoses. I did run a line back and tied in existing rear line w/ coupling. I just noticed you're working on 3/4 ton. This was a 67 1/2 to I'm refering to. Hope this helps. Greg
  1. 1967 Chevy small window SNB 350 auto 3/5 drop ps/pb {project}
  2. 1969 Chevy LWB 350 auto factory air mostly original rustfree (dependable cruiser)
  3. 2000 GMC Sierra X-Cab Z71 (Wife's ride/Grocery getter)
  4. 1969 Pontiac GTO (Restoration started. Purchased by Aunt new)
Okie Bucket is offline   Reply With Quote
Old 02-22-2007, 10:00 AM   #4
rlm316
rlm316's Avatar
Thanks Greg, That is kind of where I was going with this. I have a '85 GMC 1/2t that I was looking at for the idea on line placement. I also have a friend with a '72 1/2 power disc that he let me peek under. The difference in line placement for the bendix lines is quite different. I didn't know if there was something out of the box available. Lane
