turbo enthusiast
4wd to 2wd
when somebody is converting a 4wd to a 2wd, am I correct in saying they don't necessarily have to stay in the same weight class? Example: Taking a 1/2 ton 4x4 truck front axle out and swapping in a complete front suspension out of a 1 ton truck, control arms, cross member, etc. Maybe just change the springs.
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
Re: 4wd to 2wd
Just curious,why do you want to?
turbo enthusiast
Re: 4wd to 2wd
planning on buying a '70 Jimmy 4x4 that I will convert to a 2wd. Also have a '69 1 ton that I want to make a 4x4. Thought it might work.
Re: 4wd to 2wd
OK,I see
...Converting the 1 ton to 4x4.You plan on using a 6 bolt front axle from the Jimmy and a 8 lug rear axle?Well,I suppose you could convert it to the HD44 with the bigger 3/4 ton hubs to match Last edited by 1969k10stepside; 02-23-2007 at 10:29 PM. |
![]() Join Date: Oct 2006
Re: 4wd to 2wd
For the love of all that is truck man..... dont do it!!!!
But if you did, it would depend on the frames. If the frame was the same from 1/2 ton and 1 ton then it would be a 1 tone if tou swaped in the corect axles and springs, however I have never seen 1/2 ton and 1 ton frames that are the same. for our trucks I believe the 1/ and 3/4 are the same frame, but the 1 tons used th taller 8" frame. |
#6 | |
Re: 4wd to 2wd
turbo enthusiast
Re: 4wd to 2wd
I forgot about the 6 lug on the Jimmy. Well, it was just a thought. Thanks guys!
Re: 4wd to 2wd
Dont let the 8 lug /6 lug stop you.You can pick up the 3/4 ton hubs to bolt in in place of the 6 lug hubs .You will need different lockouts though
Re: 4wd to 2wd
I turned my 71 Blazer from 4x4 to 2 wheel drive by finding a 73 front end and just had to drill a few holes.
