Old 02-24-2007, 11:59 AM   #1
phishfud
Window squirters on all the time?
My wipers/washer system was working fine, but now the squirters are always on. No matter where I set the switch, it just pumps out fluid until there is no more, and even when empty, the wipers are slow since the pump is pumping. Not sure if this is a common problem, but hope to get a good starting point before I throw parts at it. I suspect the wiper switch, but not sure. This is an 84 with cruise and delay wipers on the column. Any info would be great. Thanks.
Terry
84 K10, 350 Auto
72 Chevelle, 454 4spd.
78 Trans Am 400 4spd
88 GTA 350 Auto
94 Cherokee
phishfud is offline   Reply With Quote
Old 02-24-2007, 11:27 PM   #2
beaterC10
Re: Window squirters on all the time?
My 84 did that. Mine was the result of the cam mechanism in the pump hanging up. I tried repairing the pump, it worked for a while and starting the same routine.
beaterC10 is offline   Reply With Quote
Old 02-24-2007, 11:31 PM   #3
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
I get that sometimes. Infrequent enough that I thought it was the switch. All of my switches are goofy.
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 02-25-2007, 09:12 AM   #4
phishfud
I checked it out yesterday, and it seems the white gear/cam is just worn away on a few teeth, so it gets stuck. At least I know how to fix it it now, it was driving me nuts! Thanks for the input.
84 K10, 350 Auto
88 GTA 350 Auto
94 Cherokee
Old 02-25-2007, 10:57 AM   #5
PhilaTruck
PhilaTruck's Avatar
Me too. Now that's one switch I won't need to replace. Thanks-
Subscribe here!
Old 02-25-2007, 11:49 AM   #6
piecesparts
Parts and more parts
piecesparts's Avatar
You may have to rebuild the pump/park switch on the wiper motor. They had problems with those, so there is a kit out there to repair it.
