08-29-2002, 10:26 PM | #1 |
bed wood
has anyone converted a steel floor to wood?
i am curious as to what method is used to allow for the thicker wood strips to keep the body lines matched up. I am assumming that the cross members are not as tall. does anyone know for sure? thanks
1971 Cheyenne Super Soon to be converted to '68 front clip. Efland, NC |
08-29-2002, 10:46 PM | #2 |
You need crossmembers, front bed panel and tail pan to do it right. OR crossmembers and notched wood on the bottom of each end so it sets level with the tail pan and front panel. after it's installed it looks just like a factory wood bed.
Rest in Peace Ed. Thanks for all the good times. |
08-29-2002, 11:23 PM | #3 |
are you refering to the crossmembers on the frame or the box?
Is a frame different for wood bed than steel bed? If so then when I look for a frame how can you tell the difference between frame that had a steel vs wood floor.
08-29-2002, 11:25 PM | #4 |
im pretty sure it is the crossmemebers that lay parallel to the axle (the separate ones that go under the wood but above the frame) that are different. i could be wrong, but i am like almost positive that the frames dont change.
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
08-30-2002, 12:28 AM | #5 |
I think they are the same. I think the only difference is the front panel, and the back cross sill. I haven't seen different ones based on steel or wood floors for the cross sills under the bed, just the front and the back. As far as the frame, the only difference might be a heat shield over the muffler to keep the heat from the wood, but that I think mounts on the cross sills and not the frame.
Just my nickel's worth...
------------------------------------------------ I say it's only money, my wife says it's only a truck.... '71 C10 Deluxe, factory ac, ps, pb, should be done by 2102 Longmont, CO husker95@hotmail.com |
