02-25-2007, 10:47 PM | #1 |
pitman problem please help!!!
Ok, so I am rebuilding the entire suspension/steering on my 78 c10, I installed the new p/s pump, hoses and gearbox, bled the p/s with the pitman arm disconnected so that I didn't have to lift the front of the truck. Then I went to connect the pitman arm to the gearbox and found that the pitman shaft has 3 flat spots on the spline shaft versus 4 on the arm so they will not fit together. The gearbox is a reman from autozone part # 7512 and the pitman arm is the one that was on the truck. Autozone is ordering a gearbox from a different manufacturer to compare and see if the first one was just a mistake. My question is does anybody know if the pitman arm on my truck is the original, and if not, what is the part# for the one w/ 3 flat spots. Thanks for any help.
02-26-2007, 01:00 AM | #2 |
Re: pitman problem please help!!!
I think the arm will go OK, the extra flat is for extra interchangability?
1970 long fleet, 355 4 speed, primer, walnut goodies |
02-26-2007, 02:46 AM | #3 |
No, I already tried fitting them together. The flat spots on both shafts are spaced evenly so one is divided into thirds and the other into fourths.
