Old 02-26-2007, 12:16 PM   #1
1badbowtie
Exclamation Suburban Headlights Malfunctioning?
I know my rig is a little newer for this Forum, I'm just exploring everyones knowledge out there.
I have a 98 Suburban, 1 headlight went out, so I replaced both low beam bulbs, worked fine for about a week, and now daytime running lights work fine, but when I turn the headlight switch to on, the headlights go out, and the brights don't work either, but if I turn the switch to the off position, the daytime running lights work fine, not sure what this problem could be?? Headlight switch?? Relay?? I sure hope someone out there has had the same problem.
Thanks,
ANDY
1badbowtie is offline   Reply With Quote
Old 02-26-2007, 01:12 PM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Suburban Headlights Malfunctioning?
had the same thing happen on my dads 2000 NBS tahoe. we replace the headlight switch =nothing replaced the bulbs= nothing replaced some wiring= worked for a while then quit. IT ended up being a malfunctioning high beam switch. so we replaced the turn signal/wiper/highbeam switch and worked fine ever since
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 02-27-2007, 10:34 AM   #3
1badbowtie
That's odd it would be a high beam switch affecting both beams. I think I'm just going to check the relay which is the center point and go from there.
Old 02-27-2007, 06:38 PM   #4
1badbowtie
Maybe the headlight switch? but why would the daytime running lights remain lit, are they on a different circuit?
