Old 02-26-2007, 05:31 PM   #1
97guns
TH350 - lost all fwd gears but have reverse
anyone know if i need a new tranny?
'71 LWB 350/350 banana yellow
'02 VW GTI turbo 14 sec. 1/4 mile
97guns is offline   Reply With Quote
Old 02-26-2007, 05:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: TH350 - lost all fwd gears but have reverse
What's the fluid level... checked in park with the engine running after going through all the gears
What color is the fluid
What's the fluid smell or taste like?
Are you sure the linkage is actually working, both in and out of the tranny... should hear a definate click as it goes into each selection.
Old 02-26-2007, 05:52 PM   #3
WorkinLonghorn
WorkinLonghorn's Avatar
Should taste like cherry cool-aid.
Do NOT attempt to put it in gear or even run the engine until you have checked the fluid,the filter,the valve-body connections and the linkage etc as LHM has mentioned.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 02-26-2007, 05:55 PM   #4
Longhorn Man
good save.... fluid level is vital. Ensure it is good before you go trying to rev it up in drive or something.
Old 02-26-2007, 06:38 PM   #5
Myself
No forward and have reverse=bad trans.
Myself is offline   Reply With Quote
Old 02-26-2007, 06:58 PM   #6
Longhorn Man
Probably, but you gotta cover the basics first.
And I have seen the shift linkage come disconected inside the pan where it controls the little piston deal, this caused this exact symptom on my last truck, it would go into neutral, but no further, yet, the shifter would move making me think I was in gear.
Odds are though, it's a bum tranny.
Old 02-26-2007, 07:02 PM   #7
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
if the fluid is low, it will eventually shift into gear if you rev it a little. I wouldnt do this very long though. Tranny fluid is cheap, rebuilds aren't.
My LED Website
My Photobucket Album of LED's
Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK
I also do LED:
-Third Brake/Cargo
-Brake (truck and burb)
-Reverse (truck and burb)
-67-68 Front Turn Signals
-69-70 Front Turn Signals
-71-72 Front Turn Signals
-GMC Front Turn Signals
I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once
Norwood Survivor
724x4a/cchevy is offline   Reply With Quote
Old 02-26-2007, 07:15 PM   #8
As2rd
As2rd's Avatar
Should the linkage be exposed when you open the pan? I never opened mine but the shifter has too much slack internally. Sorry for going a little off topic.---Andy
1972 Chevy Truck
350ci/th350 Auto.
Daily Driver
As2rd is offline   Reply With Quote
Old 02-26-2007, 07:12 PM   #9
97guns
the fluid was low and i added a quart to bring it up to full. when i put it in a fwd gear there is no surge or anything.
Old 02-26-2007, 07:22 PM   #10
Sonny
Active Member
Ouch, a quart is a lot to loose. What did the color of the fluid look like? Dark fluid means bad things. You may get lucky by changing the filter. I am sure a tranny expert is lurking on here somewhere...
Sonny is offline   Reply With Quote
Old 02-26-2007, 08:40 PM   #11
WorkinLonghorn
The prognosis isn't too good. Usually a trans that is just low on fluid gets fryed then the driver stands on the peddle trying to get his vehicle to move.
How many miles on the tranny? Condition of fluid is...?
Also a quart low,IIRC is not enough to run dry since the pan holds 2.5 quarts.
