02-26-2007, 10:54 PM | #1 |
Serial # Location TH400?
I was trying to figure out if the TH400 transmission in my 72 C10 was original. I had the hump off the other day and found the tag on the passenger side of the case with some #s on it. Is this the serial # tag? or is it stamped in the case somewhere?
Thanks |
02-27-2007, 09:42 PM | #2 |
Re: Serial # Location TH400?
The tag decodes the year ...usually the second number is the year.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
02-27-2007, 10:14 PM | #3 |
I was told or heard that part of the serial # of the engine and trans should match the vin of the truck. I haven't found the serial # of the engine yet but the casting # I found is correct for a 72 402 anyway (3999290).
How do you figure out if it is a "Matching Numbers" truck? |
02-27-2007, 10:24 PM | #4 |
02-27-2007, 10:27 PM | #5 |
http://www.nastyz28.com/sbchevy/sblock.html
http://www.nastyz28.com/bbcmenu.html...FTjTJAod8jJ2gw http://www.nastyz28.com/chevy-engine...ngs.php#suffix http://www.nastyz28.com/chevy-transm...tification.php Last edited by Rod; 02-27-2007 at 10:29 PM. |
02-27-2007, 11:06 PM | #6 |
Thanks Mr. Rod!
03-10-2007, 05:38 PM | #7 |
I found T0406TLM stamped on the front pass side of the block on a pad just below the cylinder head. The guide said it should be above the timing chain cover at the center of the engine.
So far : Tonawanda, April 06 Guess I will look for the clock next! Last edited by Texasdeere; 03-10-2007 at 05:43 PM. |
