Old 02-28-2007, 08:11 AM   #1
short step
Cab interchange
Will a 67 and 71 cab interchange
short step is offline   Reply With Quote
Old 02-28-2007, 08:19 AM   #2
arkracing
Weekend Warrior
Re: Cab interchange
Yeh they'll all interchange, but the mirror may be attached to the W/S instead of bolted to the header in the cab.
the E-brake may be a hand operated in the '67 and foot operated in the '71
Make sure that if you currently have a "high hump - bolt in center floor" that the replacment is the same - you can make a "low hump" a high hump but it takes a little work.
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 02-28-2007, 06:37 PM   #3
Bob Moore
Re: Cab interchange
The other area of difference is the throttle linkage. The 71 uses a cable and the 67 uses a rod. The 71 should fit the carb with only a stud added.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 02-28-2007, 06:53 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Cab interchange
it'll work, but not a 100% direct replacement.
The parking brake is the foot kind, not the hand type, and it'll be a HUGE hassle to swap out.
The fuse box/harness/dash switches are all different from yours... again, I'd just run the new stuff.
The throttle will be cable instead of rod... safer, but probably needs a new cable.
