steering column ?'s
Hey, I'm changing out my steering column for one with tilt wheel, and my donar has automatic lever on it and my 73 has a 4 speed on the floor, someone showed me before where I could buy the part to replace the part on the column with the shift lever to one that doesn't, and I lost the info. Anyone with help again? thanks Tyjoja
Re: steering column ?'s
It is a pretty common street rod piece. I believe Yogis and Speedway have them.
The One And Only !!!
Since I'm going from no tilt auto column to tilt floor shift auto I plan on removing the shift lever grind the area smooth and fill the hole then re-paint.
I figured the money spent on another column bell could be spent else where.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
