Old 03-04-2007, 11:02 AM   #1
3/4tonterror
3/4tonterror's Avatar
Help, Broke Both Axles
I need help. I just broke both axles on the passanger side front dana 44 [closed knuckle 68 3/4]. i need to know if the axles are the same on 1/2ton as a 3/4 ton closed knuckle.
Another ? what year did they stop putting the closed knuckle in these trucks? thanks for any help.
3/4tonterror is offline   Reply With Quote
Old 03-04-2007, 12:27 PM   #2
Re: Help, Broke Both Axles
`69 for closed knuckles.I think they`re the same.Just different at the spindles-out.This sucks.So,you want to keep it original?You prolly know it`s easier to go newer at this point.So you broke the shafts and the housing`s ok?Did the knuckle grenade and your yokes got trashed?Or,both shafts actually broke?Are you into it,yet?
Old 03-04-2007, 12:49 PM   #3
3/4tonterror
housing is fine just the yoke took out both axles, now what?
Old 03-04-2007, 03:37 PM   #4
PM Americanrider.He may,and I say may,be able to help.You could post a thread in the 67-72 message board asking if there`s a good source for these to check.Don`t word it as a want to buy,though.And,ask that it not be moved back over hear as you need to reach all you can asap and it`s as much 67-72 as it is 4wd related.I wish I could help.They`re going to have to come out of another un-used axle.Would you consider swapping to newer?If not just temporary?
Old 03-05-2007, 05:31 AM   #5
earl87gta
earl87gta's Avatar
thier was just a hole axle on ebay up your way start bid no reserve was 25 no one bid on it. wish I would have saved it in my watch list longer now. If you cant find any thing PM me and mabye I can help. I would also PM msgross I think he has one for sale cant remeber if its a 3/4 or not.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 03-05-2007, 08:13 AM   #6
3/4tonterror
If i up date to a disc front end it seems like a straight forward swap. But how about the drive shaft. [ i got a t-221 transfercase].Also if i use a 73/up diff, is it still just a bolt in?
Old 03-05-2007, 01:12 PM   #7
earl87gta
earl87gta's Avatar
Its bolt in the only thing you may need to change is the break lines. I used an axle from an 84 whrn I did my swap.
Earl
Old 03-11-2007, 06:15 PM   #8
jacobs
jacobs's Avatar
Make sure your new one is the same gear ratio as your old one.
jacobs is offline   Reply With Quote
Old 03-05-2007, 02:10 PM   #9
3/4tonterror
Thanks Sounds Like What Ill Have To Do.
Old 03-05-2007, 07:25 PM   #10
earl87gta
earl87gta's Avatar
unless you are just wanting to keep it origanal I would just put the newer axle in it. If you can get one from a 72 so you can have the flat top knuckles incase you ever want crossover steering.
Earl
Old 03-06-2007, 12:19 AM   #11
bloertcher
bloertcher's Avatar
Actually,it's hit and miss on the knuckles,I've had axles as late as 77 that had the flat knuckle on the passenger side.
RIP Baby Jack 2-06-07
See You On The Other Side My Little Man
bloertcher is offline   Reply With Quote
Old 03-06-2007, 12:05 AM   #12
You can swap-in a newer axle and search your rare parts in the meantime to go back original,if you want.
If your going to a disc brake axle,you`ll have to address the rest of the front brake system,too.
Old 03-11-2007, 06:34 PM   #13
msgross
msgross's Avatar
I still have my 1/2 ton closed knuckles... let me know if you need something.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-13-2007, 09:27 AM   #14
3/4tonterror
im all set, picking up complete disc front end from a member thursday, thanks guys.
Old 03-14-2007, 06:18 PM   #15
Cool,I just found out about a`68 K/20 for sale for $1,500.Bed rough,but rest of body good and a fresh-built 383($2,500 in reciepts).I thought about you needing an axle.I`d have bought it for the motor and parted the rest.
Glad you`re set.
