03-06-2007, 04:44 PM | #1 |
RCI Fuel Cell placement
I have this cell. It was in a truck my son had bought. I want to mount this cell under the bed. Has anyone done it? Any issues? I'm going to put a fuel door in the floor to fill it. My concern is that it appears to be designed to be mounted in the bed or trunk. Not sure if I will need to put a piece of plate under it to support it or if the straps will provide enough support.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear Last edited by fade94; 03-06-2007 at 04:46 PM. Reason: Added info. |
03-06-2007, 05:02 PM | #2 |
Re: RCI Fuel Cell placement
I have seen someone use the straps from summit but summit didn't recommend using it in that fashion. Maybe if you placed a piece of metal it would work, if you already have it then why not try...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-06-2007, 05:11 PM | #3 |
My thoughts as well. I was going to make my own straps anyway since the cell was just in the back of a parts truck. Going to use approx 3" wide straps with 2 more the same size running both directions under the tank to support it.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
03-06-2007, 08:12 PM | #4 |
Here's what summit has for $25. I would think that it might sag in the middle but should work great with some extra support...
http://store.summitracing.com/partde...5&autoview=sku
03-06-2007, 09:20 PM | #5 |
I saw those too. RCI (my cell brand) has them as well for around the same price. I think if I run and extra piece or two between the straps it will hold up just fine.
