Power Brakes F/s (72)
Either complete or parts. You decide. From a 72 C20
Booster w/ master cyl and prop valve and brackets 45.00 SOLD Calipers, lines, spindels, backing plate and rotors (could use turning), 100.00
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins Last edited by WORNBRAKES; 03-20-2007 at 10:50 AM. |
Re: Power Brakes F/s (72)
Ttt
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
shipping estimate to 27713?
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
What would also be needed to use those to convert my '69 C20 drums to disc? Can someone tell me if those would those work with my control arms and tie rod ends?
GMCbubba, My scale broke. I am getting another one today and will get you a quote. Were you interested in all of it?
Snew, I looked at LMC's catalog and found different P/N for the upper and lower balljoints and outer tie rod for 71/72 3/4 Ton and the 67-70 3/4 Ton. I am not sure if the diamiters are a different size.
yeah WORN, i'm interested in it all. it would be shelved for a later conversion, but the price seems to be about right to get it now. plus, there isn't too much 8-lug stuff that i've stumbled across...
Bubba,
I checked a few diff shiippers and this is what I come up with for the items listed below: brake booster 35lbs 23x21x21 spindel/caliper/rotor 90lbs 18x18x14 X2 spindel/caliper 70lbs 18x18x14 booster, w/rotors, w/out rotors DHL- 22.00, 44.00 X2, 33.00 X2, Fed EX- 29.00, 50.00 X2, 33.00 X2, GREYHOUND- 38.00, 70.00 X2, 60.00 X2, Please let me know what you would like to do. Thanks, Mario
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins Last edited by WORNBRAKES; 03-12-2007 at 07:52 PM. |
mario, thanks for checking that out. with that almost doubling the price, i don't think i can make that commitment right now. plus, new baby coming in a week. still seems like a good deal for someone, though.
--michael
It is heavy but someone must need it?
![]() Join Date: Aug 2005
Let me know if your willing to split it up; I only need the m cylinder and prop valve. If so, price + shipping to 77345?
![]() Join Date: Jan 2007
If you will split the brake setup and Ole Blue takes the master and prop valve.
I will take the booster with pedal rod, and brackets. Shipping to Ft.Worth76133 or Will you be at the La Grave Swap Meet April 7th & 8th.
![]() ![]() ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=157669 http://www.67-72chevytrucks.com/vboa...d.php?t=375640 |
I will split them.
Ol blue- 22.50+10.50 shipping =33.00 total n2gmtrux- I will not be at the swap meet. I may not be in town. For you, 22.50 + 11.50 = 34.00 Please let me know what you would like to do. Thanks
For you, 22.50 + 11.50 = 34.00 ![]()
#15 |
Booster and master cyl SOLD.
spindles, backing plates, calipers and rotors still available.
#16 |
Ole Blue- shipped USPS today
#17 |
M.O. sent by mail today at 3:50PM,,,,,,, Thanks
