03-07-2007, 10:57 PM | #1 |
Grant Steering Wheel NEW
Grant Steering Wheel: Formula GT Mahogany Wood Finger Grip, Polished Aluminum 3 Spoke Design
New, removed from box planning on installing in Blazer. Decited to go with a more all weather, cheaper, nobody wants to steal from the convertiable wheel. Comes with install kit Grant P/N 3196 It has 1 minor rub mark on top. Wheel and kit new, $135.00 Mine $95.00 shipped in lower 48 FIRM
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins |
03-08-2007, 02:16 AM | #2 |
Re: Grant Steering Wheel NEW
I hsve a question is the kit for your Blazer the same as the 67-72 truck ? If so pm me please with your info Mike
hav'n fun be'n me |
03-08-2007, 10:05 AM | #3 |
chevy truck fan
if it will fit(w/o mods) on a '72 chevy truck stock non-tilt column then i will put my self in line behind "muddyole69"
how bad is the scratch on the wheel?? thanks!! rodstored-72 |
03-08-2007, 12:25 PM | #4 |
I got thirds? LMK if it gets this far.
03-08-2007, 12:45 PM | #5 |
Gents,
After doing some home work at your request, I found that I had purchased the wrong kit for our year trucks. The P/N 3196 kit is for 74-94 chevy truck with no airbag. http://www.partsamerica.com/productd...artNumber=3196 The correct kit is P/N 3163. Sells for 20.00 at the store and 2 are on ebay right now for the buy it now price of 14.99. http://www.partsamerica.com/productd...artNumber=3163 http://cgi.ebay.com/ebaymotors/3163-...QQcmdZViewItem I am sorry for the incorrect information. I will sell the wheel seperate for 85.00 SHIPPED or You can attempt to exchange this kit for the right one for 95.00 SHIPPED for both. Again I am sorry for the mix up. Please let me know what you would like to do. I will respect the order of the replies. Thanks, Mario
03-08-2007, 01:11 PM | #6 |
Led Sled! Discs R 4 ME!
FYI.
I purchased A 3163 for my 72 and a 3196 for my Stepsons Monte. I really wanted a 5163-1 (billet aluminum) for the truck but it was a special order and big bucks. The diameter of the stamped steel "collar" was the right size on the 3163 but the lead splined hub piece was the wrong size. I tried the 3196 and the splines fit even though the collar was a little larger in diameter. This allowed me to use the 5196-1 hub. The diameter at the column is a slight bit larger but will fit to the column well. I also put in the small spacer that came with the kit and it does not need it. I will need to remove it. I will try to take a picture tonight if anyones interested. fwiw, I'm using the same wheel and needed to adjust the turn signal lever a bit more forward for finger clearance. |
03-08-2007, 01:49 PM | #7 |
Thanks, Denny for the practical version of the install. Correct me if I am wrong but you are saying that the collar in the 3196 fits better than the one in the 3163 kits.
Thanks again, Mario
03-08-2007, 02:16 PM | #8 |
No, the collar on the 3163 is the same diameter as the column. The 3196 is a larger diameter than the column and will sort of go around the column.
I have no Idea why the lead hub in the 3163 kit did not fit my 72. Mine is a factory tilt, this could be a factor? Denny |
03-08-2007, 03:23 PM | #9 |
chevy truck fan
i am interested in the st. wheel still if muddyole passes. i will just try to get the correct kit local from a auto store...
03-08-2007, 05:48 PM | #10 |
Rod, I sent a PM to muddyhole. I will let you know.
Mario and Mandy Hughesville, MD 20637 69 C10 305/350 71 K5 Basket case 75 K10 Rescue **Parting out** 77 MG Midget **Parting out** 15 6.7L Cummins Last edited by WORNBRAKES; 03-08-2007 at 05:48 PM. |
03-09-2007, 10:11 AM | #11 |
Put me in line if everyone else falls out....I miss that wheel, had one on my Elky and loved it!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
03-09-2007, 11:09 AM | #12 |
This is the 5196-1 hub on the 72
03-11-2007, 02:19 PM | #13 |
chevy truck fan
gents,
i am passing .... thank you though.... rodstored72 |
03-11-2007, 08:57 PM | #14 |
fyi, I have passed on this Mike
hav'n fun be'n me |
03-11-2007, 10:23 PM | #15 |
Mario,
What ragtop do you have? |
03-12-2007, 12:39 PM | #16 |
If you mean for the Blaz, I made one to cover the flight station only this past weekend. I am currently finnishing it up. I have been using a 10 mil tarp. lol
