![]() Join Date: Jul 2000
Throttle cable/rod
I am getting ready to install a new engine in my 68. I am thinking about going to a cable type throttle set up. Has anyone installed a 71 /72 type or after market throttle cable. If so, any problems?
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
![]() Join Date: Dec 1999
i just did this on my 69 a couple weeks ago. the throttle/kickdown ratio on with my 700r4 wasnt right with the rod so i found a guy i the paper that had a bunch of extra 67-72 parts and bought a cable set up off him for $20.
i had to drill a hole in the filewall, no problem there. then the bracket that bolts the pedal to the firewall has some kind of a housing that covers the cable from stuff interferring with it but i cut that off cuz i had too much crap under there for it to fit but nothing messes with the cable. and the three bolts for the 71-72 set up dont fit the three bolts for ous so i just used the bottom one then drilled one of the top ones and bolted her up. no problems since and im a lot happier with it cable. let me know if you want any pics and of what
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust |
