tming issues
how many degrees of timing should i set my 454 to?? here is the set up,1994 454 gen 5 converted to carburetor with an eddie mani and carb with an HEI dizzy. my book says to set it to 4 degrees btdc, but since the whole set up has changed, then i'm not sure if to set it to the fuel injection set up. I JUST got finished with the swap, so i want to gt it running properly asap. thanx a lot
Re: tming issues
and up we go! lol, l throw i a pic to lure people .
![]() Last edited by combustion; 03-13-2007 at 02:58 AM. |
Re: tming issues
my guess would 8* BTDC, looks nice to btw
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
Re: tming issues
oh ok, ya that is what my dad suggested, but i wanted to get a different opinion since he was not so sure either. but a, the picture does no justice, that flash shows all the imperfections i dont want it to show lol =P il thro another pic just for the giggles ![]() when i first got the motor ![]() when i was halfway through my build ![]() Last edited by combustion; 03-13-2007 at 03:42 AM. |
Re: tming issues
good progress, whats it out of?
Re: tming issues
if im not mistaking it was of a 1994 2500 p/u.
it has a eddie performer 2-0 750 cfm carb carter fuel pump, (since the block cannot accept a mechanical one due to tbi) the whole serpentine belt assembly internal voltage regulator conversion dual bolt patern hughes performance flexpate HEI assembly. and a electric fan assebly i am still runing the th350. i hope it dont brake, it has never been rebuilt and its not designed to handle much power stock. plus i owe my dad quite a bit of money since i used all mine up in the fuel set up pretty much lol. i found a picture of my old motor. it was and old and tired 307. i took it with my phonw thats why is a little blurry ![]() Last edited by combustion; 03-13-2007 at 04:16 AM. |
Re: tming issues
gota love the serp setup I need to steal the one that I put on my k5 for my c10 but looks good hopefully you can get that things running smoothly.
1985 ![]() Last edited by Rascal_one2001; 03-13-2007 at 08:47 AM. |
Re: tming issues
The simple answer is to set to whatever initial timing is required to get 36 degrees total advance (initial + mechanical advance) at < 3000 RPM. You can then tune the vacuum advance. I posted an attachment in this forum that details the process. This a proven approach for max power and driveability.
"Power timing" will always be far too advanced. |
#9 | |
Re: tming issues
thanx a lot for your replies i will check that out for sure. you guys are awsome ![]() |
#10 | |
Re: tming issues
Re: tming issues
Here you go - this is the very best guide I've ever read, and Lars is a legend in the Corvette community with MANY success stories to tell.
Re: tming issues
thanks Billa
Re: tming issues
But Billla, what is to much timing when you say a smallblock can have 52 degrees advance? When it pings, its to much timing, no ping its good
