Old 03-12-2007, 08:46 PM   #1
jkade
jkade's Avatar
NP 241 to SM 465?????
The suburban has a 241 and a 700r4. Can I make the 241 work with my 4 speed???
jkade is offline   Reply With Quote
Old 03-13-2007, 04:07 AM   #2
rcbildr
rcbildr's Avatar
Re: NP 241 to SM 465?????
The 700R4 has a 27spline output and the SM-465's have either a 10 spline, or a 32 spline output. Assuming you have the 32 spline SM-465, you would have to replace the input gear on the NP-241. I've done the swap on an NP-208 and it's pretty easy to do, not sure about the NP-241 tho. Hope this helps.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 03-13-2007, 10:01 AM   #3
Jonboy
Slots go on anything!
What are the main differences between a 208 and 241? I know that the 241 has the provisions for the electric VSS, but what else is different? They look the same.
Jonboy is offline   Reply With Quote
Old 03-13-2007, 12:02 PM   #4
rcbildr
rcbildr's Avatar
Somebody correct me if I'm wrong, but I think the NP-241 has a lower gear ratio, is a little stronger, and there is a slip-yoke eliminator kit available where there isn't one available for the 208. IIRC you can adapt part of the NP-241 to the 208 to use the slip-yoke eliminator kit, but I'm not 100% sure on that.
My Projects:
1978 Camaro Z28
Old 03-13-2007, 01:14 PM   #5
Russell
Professional Grade
Russell's Avatar
Yep, get a 32 spline SM465, with a 208 adapter and bolt the NP241 straight up. The 241 is lighter, and quite a bit stronger than a 208 is
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-13-2007, 08:09 PM   #6
jkade
jkade's Avatar
I have a 208 on the 465 right now, should the 241 bolt up then? I am going to keep the 241 for a spare.
Old 03-13-2007, 08:44 PM   #7
Russell
Professional Grade
Russell's Avatar
Yep, SM465 / NP208 combos are all 32 spline, so assuming you have a 32 spline NP241, it will literally bolt directly to the NP208 adapter.
