03-14-2007, 07:50 PM | #1 |
Luv the Crewcabs
Is This High Temp Paint any Good?
Any one ever use this on Manifold's & what were the Result's?
Thanks,, Rick |
03-14-2007, 09:52 PM | #2 |
Re: Is This High Temp Paint any Good?
Never used that brand I have used the duplicolor Hi Temp paint but it should work just fine. Just make sure its clean before paint. Prep work is the key.
2004 Chevy Silverado 1500LS SWB 5.3L 2004 Corvette Z16 #770 Wish I had not sold 72 blazer Last edited by 65-72 chevytoys; 03-14-2007 at 09:53 PM. |
03-14-2007, 09:57 PM | #3 |
I think thats the stuff I used, and it worked just fine. Just make sure you degrease your motor first, it there is dirt the paint will not bond and will flake off.
Let me tell you what Melba Toast is packin' right here, all right. We got 4:11 Positrac outback, 750 double pumper, Edelbrock intake, bored over 30, 11 to 1 pop-up pistons, turbo-jet 390 horsepower. We're talkin' some ****in' muscle. -Wooderson From the movie Dazed and Confused |
03-15-2007, 08:23 AM | #4 |
For best results,blast first.
03-15-2007, 10:26 AM | #5 |
yup!
03-15-2007, 12:46 PM | #6 |
No! I would recommend normal car primer, paint and clear.
03-15-2007, 01:26 PM | #7 |
...and if you get any oil on the exhaust manifolds or headers after painting, be sure to clean it off before running the engine because it can stain bad.
03-16-2007, 08:25 AM | #8 |
The secret to painting exhaust manifolds:
1. sand blast 2. paint with a very light coat, just enough to put color on it. NO PRIMER 3. If you have access to an old stove, bake them at 400 deg. for about 30 min. If not install them and run the engine for short periods of time until well baked to the metal. If you don't sand blast them, paint will never stay on them.
