Old 03-14-2007, 09:49 PM   #1
Rc 415
Flat Black, & Chrome!
Rc 415's Avatar
You tell me, blowing oil, or condensation?
What do you think?
1983 Chevy C10 Stepside Sold
http://s69.photobucket.com/albums/i76/rc_415/
Rc 415 is offline   Reply With Quote
Old 03-14-2007, 10:13 PM   #2
lurch115
lurch115's Avatar
Re: You tell me, blowing oil, or condensation?
from those pics its hard to tell....if its oil the cloud will have a blue tint to it...if its water it will be white
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-14-2007, 10:17 PM   #3
Russell
Professional Grade
Russell's Avatar
Our exhaust looks like that 8 months of the year, nothing to be worried about
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 03-14-2007, 11:38 PM   #4
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
loooks like to me just a truck tha sat for some time and may have gotten a bit of moisture in the pipes drive it for a bit it will go away.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-15-2007, 12:58 AM   #5
bigtruck81
condensation. oil smoke will hang around and not dissipate like that did.
bigtruck81 is offline   Reply With Quote
Old 03-15-2007, 06:40 PM   #6
Donnylee
Donnylee's Avatar
Looks like condensation to me..If you look at the picture of your exhaust pipe you can see a puddle of moisture laying at the bottom... The real quesion is how much oil are you using? I agree with Russell and Lurch..........Pretty common in good old Oregon where I live
Would you rather be eating Government Cheese down by the river, and living in a C-10~!
Donnylee is offline   Reply With Quote
Old 03-15-2007, 07:55 PM   #7
Rc 415
Rc 415's Avatar
What do you mean how much oil am I using? How many quarts i have in it?
Old 03-15-2007, 10:52 PM   #8
Zilverado
Zilverado's Avatar
What he is asking is how much oil (if any) does the engine burn? Do you need to add oil between changes to keep it on the "full" line on the dipstick? If so, and it is not leaking oil, that means you could be burning it - - possibly bad piston rings...
Zilverado is offline   Reply With Quote
Old 03-15-2007, 11:12 PM   #9
Rc 415
Rc 415's Avatar
The oil level has never dropped on my, guess that means I'm good there.
Old 03-15-2007, 07:46 PM   #10
Zilverado
Zilverado's Avatar
I agree - I think it's condensation. Looks a little too "light" (as in not heavy) to be oil. You should also be able to smell the difference. Does it do this just for a while at start-up or all the time? Heavier under excelleration?
Old 03-15-2007, 07:56 PM   #11
Rc 415
Rc 415's Avatar
It does have a smell to it, and it does it for a few minutes after startup, and after I accelerated and let off the gas.
Old 03-15-2007, 11:02 PM   #12
Zilverado
Zilverado's Avatar
What is the smell like? Burning oil smells just like that - burning oil. A "sweet" smell indicates burning coolant (antifreeze). Burning coolant could be a result of a broken head gasket - allowing coolant from the engine's water jacket into one or more cylinders, where it gets burned by the engine combustion. Do you ever notice your radiator coolant level dropping?
As for the acceleration point I asked about - - engines with bad rings will smoke (burn oil) under heavy acceleration.
I'm thinking you could be burning engine coolant.
Old 03-15-2007, 11:16 PM   #13
Rc 415
Rc 415's Avatar
Well, I've never smelt burning oil, but this doesnt smell bad really, I wouldnt really say it smells sweet though, but mabye thats what it is. I havent checked the radiator coolant level in a while, I'll do that tomorrow.
Old 03-16-2007, 01:51 AM   #14
Srubydo1986
The Crazy Machanic
If hes gets water into the combustion chamber that would cause for some water/coolant to get into the block, correct?
And if thats happens there would be water in the oil so if he were to pull the dipstick there would be a brown foam like stuff on the stick or under the valve cover cap.
Iv had it under the cap alot in all my cars, What it was in mine was just mosture from sitting. Because im lazy and it was in my chevelle at the time i would drive the car to school take cap of and when i got back in the car put cap back on. allowing mosture to excape the engine.
In your case if it more green then brown id say blown head gasket but the smoke would be more white right?
newest additions
Old 03-16-2007, 09:24 AM   #15
Zilverado
Zilverado's Avatar
And if thats happens there would be water in the oil so if he were to pull the dipstick there would be a brown foam like stuff on the stick or under the valve cover cap...
Fortunately, in my 20+ years of vehicle ownership, I have never had (to my knowledge) a blown head gasket, and I am not a mechanic by trade - so I am speaking more from what I've heard and read.
I don't know if water/coolant in the oil would be an absolute definite result of a broken gasket. I would think that the water could possibly get into the cylinder only - to get burned - and not into the crank case. But if it does get into the oil, yes, it will cause the oil to foam and the underside fo the cap will usually show the brown foam as you indicated.
I guess another way that water could get in is a cracked block or head itself. In the case of the block, this would most likely lead to water in the oil.
Yes, burning water/coolant will result in white smoke. Burning oil is usually more blue.
Old 03-16-2007, 11:36 AM   #16
Donnylee
Donnylee's Avatar
My bet is its nothing more then moisture in the exhaust. If it is a cool morning when you start it up its very normal occurance. If you can breath out through your mouth and see what looks like steam its kind of the same phenomina with hot warm exhaust. I see cars steaming out the pipes all the time in the mornings at stoplights! Its mainly because of the hot warm exhaust escaping into the cool moist air. If your not using oil and your not loosing coolant I think you can relax. There is probably nothing wrong with your truck.
Old 03-16-2007, 12:12 PM   #17
Zilverado
Zilverado's Avatar
I certainly agree with you - - depending on the conditions outside.
Old 03-16-2007, 05:55 PM   #18
Rc 415
Rc 415's Avatar
It is cool in the mornings, high 40's. But, It also happens in the afternoons. See, I only start the car for a few minutes once a day, and its usually in the afternoon when I get home from school.
Also, one of the exhause pipes got bent pretty bad somehow, can that be part of the problem?
Old 03-17-2007, 03:21 AM   #19
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
It may need a good run to fully warm up of driving 30 minutes to an hour. So the extra moisture that it has in the engine can release. Its not getting warm enough starting a few minutes a day. That will tell you a little more of what its doing. If its just the extra moisture (most likely) or if its something more serious.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
