Old 09-02-2002, 05:45 PM   #1
406chevy
Help *** Alternator ***
I have a 71 chevy truck with new 396. My original alternaotr went out days before i made the swap to the 396. So i replaced it with a stock one from the Oriely Auto parts. The alternator was working when installed( discounnected the battery while running and see if it keeps going). After two days it was no longer charging. Went back to store and got another one, this time highperformance model. Same thing happens after 3 days of driving. it is no longer working. Had them check at the parts store, they confirmed that both were not charging when i returned. What is knocking them out or what should i do to fix the problem for good.
406chevy is offline   Reply With Quote
Old 09-02-2002, 06:09 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
sounds like the voltage regulator...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-02-2002, 07:06 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That, and/or the way you are testing them.
Removing the bat cable only tells you 1/3 of the story. It only takes 8 volts to run, and only a few amps. That is not the reading of a new alternator.
Replace your alternator, and your regulater, and use a volt meter to test it all.
Sometimes (not common, but very possable) by removing the cable, you can fry a diode inside.
