#1 | ||
block casting numbers?
01 0
02 0 146 Found on the drivers side next to the oil filter on the side of the block. I was looking for some numbers to confirm this 350 came out of a 71 like I was told. thx
Active Member
Re: block casting numbers?
Funny # it should be a string of #s 7 or 8 digits long. Something like 3858618. Infact the # should start with a 3, a # that starts with a 1 for with a few exceptions is an 1980 and newer motor. Remember that somtimes 6 look like 8s and 8 look like 3s, sometimes the casting of the #s is a bit rough...
Hope this helps, -Fred |
#3 | ||
Am I looking in the right place?
72 chevy
![]() Join Date: Jan 2007
SBC on the passenger side bellhouseing flange looking from the top of the motor.
Neighborhood Pickle Slinger
Should be right here just like CrashEd said.
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 |
#6 | ||
Well the number was 3970010:
This website said it is: 150 3970010 350 CID 300,350,370 HP 1970 Normal 4 Bolt Main Corvette and late 1969 This is pretty good right?
Big Block
If it is out of a truck, should be 4 bolt main block. 3970010 is a common # used for 350 block.
Active Member
I came up with three posibilities for the casting #, I would assume that it is the second one, however it can be crossrefrenced by getting the casting #'s off of the heads. On a long shot you might just have gold on your hands
![]() Casting #...ci.......year....bolt......type/usage 3970010....302.....69........4........Z-28 Camaro 3970010....327.....69........2........Trucks and industrial 3970010....350.....69-80....2 or 4..Dealer Replacement Last edited by KFreddy; 03-18-2007 at 09:50 PM. |
#9 | ||
Where are the head cast numbers? On the front or side?
