Old 03-19-2007, 10:46 PM   #1
KMK454
KMK454's Avatar
Installed custom fiberglass tonneau cover - pics
Warning: Long Post!
How do I use a pickup bed that has original paint and bodywork with no dents or rust? How do I protect it from both cargo and weather?
After much debate between Snuglid and Gaylord products, I went with Gaylord due to available photos and past experience. I placed an order almost a month ago...
On Monday I received the following:
1. Gaylord Lids X2000 fiberglass tonneau cover painted Chevy Black
2. Gaylord Lids "California Cruiser" bedrug kit
On Tuesday I lucked out and we finished firing at the range early so work ended around 3 PM, and I immediately went to work on the install!
Installing the bedrug took about half an hour, most of which was spent figuring out where the pieces go since Gaylord didn't include an instruction sheet. The pieces are high quality and fit about as well as one could expect a custom product to fit without the builder having measured my specific truck. I guess Chevy tolerances in the 70's were strict, because all the components fit beautifully. The rug that goes on the bottom has a nice foam pad, and the carpet is soft yet durable and tough. It's not your typical house carpet, yet it's nice enough that I wouldn't mind camping out in the back of the truck!
Onto the lid, and here's where things get complicated...
Step 1: Lift lid onto the bed and line it up, measuring where it sits from the inside
Step 2: Take lid off
Step 3: Install mounting brackets
Step 4: Put lid back on and secure lid to the brackets
Step 5: Install locking device
Done!
Of course, I only had one person, so my install went like this - bring a buddy over, give him a beer, have him put the lid on with me, and then let him go... I then proceeded to lay in the back of the truck under the bed while I installed it. I don't recommend this method since it's much harder, but with some thought it will work out the same.
Proper alignment comes from a good initial fit and measuring, but a lot of it is also trial and error. I had to remove the lid again and re-align it. Luckily, it's easy to remove once the initial install is complete.
Here are some very rough snapshots of the completed product. I haven't washed the truck since the install and didn't put a lot of effort into them, so I'll take some better pictures later:
For reference, here is how it used to look. Click:
http://img245.imageshack.us/img245/5732/dsc1202ig8.jpg
Review after a day or so...
Fit and Finish - Gaylord obviously takes pride in the quality of their lids; I'm impressed with how good the paint matches and how solid the fiberglass lid is. Furthermore, the hydraulic arm and lift mechanism is proving to be solid, reliable, and sturdy. The bedrug also fit as well as I could have expected it to. For a custom product in which the manufacturer never sees the receiving truck, the fit is amazing.
Shipping - It took about two weeks to build and then another two weeks to get from California to my door, but the pieces arrived within a reasonable amount of time. Lifting the crate required some friends to come over and help. I found no damage whatsoever on the lid or the bedrug components.
Functionality - The bedrug is installed with velco stickers that are placed on the inside of the bed. From the looks of it, the rug will be able to withstand light dirt and moisture with no issue. Obviously I will try to keep it as clean as possible, though. The lid lowers and rises smoothly and quietly and seals properly when closed.
Waterproof? - The front of the lid between the bed and the cab does not fit perfectly flush, so there is a tiny crack along the leading edge where water gets in. I plan to place rubber weatherstripping along the top of the bed using double-sided tape so as to ensure that the bed is 100% waterproof. Aside from the front of the bed, though, no water entered during a heavy rain.
Locking Mechanism - This is the one weakspot; either Gaylord messed up on the bedrug design or they didn't engineer the lid to work in conjunction with the bedrug. I cannot properly mount the locking points on the bedside of the truck, so for now anyone can open the rear. Fabricating my own solution should be easy enough, and I think it will work with some shorter bolts... I will keep you updated, though.
Appearance - I personally prefer the open bed look without a bedliner or tonneau cover, but if it has to be covered and protected, this is the best way to do it. The sleek lid fits snugly and is invisible to the casual onlooker. There is a silly "GAYLORD" sticker on the back but I will remove that once the paint has fully cured; it still smells like fresh paint! The bedrug also looks great.
Price - $2000 shipped to my front door. Install Price - One afternoon and a few beers.
These pieces definitely aren't cheap, but I will say the quality, fit, and finish of the product make it worthwhile. I figured if I was going to do it, I may as well do it the right way, because that's what the truck deserves.
I hope this helps anyone who is considering doing the same. Feel free to ask any questions and I will try to answer them as best I can!
Kurt
Instagram: @kurtkphoto
1978 C10 Silverado
1991 Camaro B4C
KMK454 is offline   Reply With Quote
Old 03-19-2007, 10:54 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Installed custom fiberglass tonneau cover - pics
Kurt I think it looks pretty good. We had a cover on the first truck before it got stolen but it hid everything like you said. We had problems also with the locking mechanism, not sure if it was a gaylord since it came with the truck, but it was a pain in the rear to get locked.
I like the siccor type of hinge they went to instead of the hinge at the back bedrail. Again I think you have an awesome looking truck - I just love the stock look even with the cover.
Tom
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 03-19-2007, 11:39 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
It looks good! I would love to have one of those, but the price is just too high for an old truck like mine. I need to find a nice used one...
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-20-2007, 03:01 AM   #4
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
very nice. looks good on these old truck was kinda curious. Now lets all hope she doesnt scratch the side of the bed, like some plastic bed covers do that cover the lip of the bed.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 03-20-2007, 08:41 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Awesome install and write up. I have been considering installing a bed rug in my 06 Silverade CC. That looks sweet.
I considered a bed cover for my 77, but decided to leave it open and run a rubber mat. Yours turned out great.
One worf of advice on that sticker. Use WD-40 to get the excess glue off....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-20-2007, 10:19 AM   #6
wedgemon
wedgemon's Avatar
MMMMmmmmm, tonneau!!
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 03-20-2007, 10:27 AM   #7
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
KMK454-
That sure looks good. You did a good job.
BTW, thanks for the write-up.
...hmm, I wonder what's next???
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 03-20-2007, 09:15 PM   #8
KMK454
KMK454's Avatar
Haha, not much... you read how much the lid cost, right?
Kurt
1978 C10 Silverado
1991 Camaro B4C
Old 03-20-2007, 09:41 PM   #9
Duro5341
Duro5341's Avatar
Very Very nice...........it just finishes off the look of the truck, and increase your gas milage aswell
I have been looking for a while for one for my 86 K10, here in Ontario.....and no luck. Anyone know of a company that makes one, and won't break the bank, maybe under $1500
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 03-20-2007, 11:17 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Duro5341 View Post
.... Anyone know of a company that makes one, and won't break the bank, maybe under $1500
Duro
Try the Snug Lid by SnugTop. I have owned 3 of them now and they are premium quality lids. They are usually right at 1000.00 from my local supplier.
Articles-
"Refining Sierra"
Old 03-20-2007, 10:32 AM   #11
hiway
Mad Scientist
Looks great and good write up also. I suggest a rear bumper next. Oh....and there's not a sole on this site that wouldn't love to have that truck of yours. (alarm maybe?)
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 03-20-2007, 09:39 PM   #12
84 400
Sb 400 club
84 400's Avatar
looks pretty good and that truck is just so clean!!! good mod
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 03-20-2007, 09:49 PM   #13
bigblock73
yeller
bigblock73's Avatar
I like the new additions, they look great.
I agree with the rear bumper idea...have you considered swapping the step unit to a sport unit?
bigblock73 is offline   Reply With Quote
