Old 03-21-2007, 11:05 AM   #1
smoknbarrels
Registered Mail
smoknbarrels's Avatar
Cab mounts-Polyurathane or stock rubber???
What do you recommend I get for cab mounts?
I am planing on going polyurathane for everything else, but I was thinking of going stock rubber mounts for the cab, so it may reduce any bad vibes or perhaps be a little smoother.. think its a good idea? or will polyurathane cab mounts still give a decent ride without vibration.
Thanks!
smoknbarrels is offline   Reply With Quote
Old 03-21-2007, 11:36 AM   #2
Alvin
Never Done?
Alvin's Avatar
Re: Cab mounts-Polyurathane or stock rubber???
I have seen a few complaints about ride quality with the poly cab mounts. That was enough for me. I went with rubber cab mounts and rubber for the trailing arm bushings. Saved some money, and should ride at least as good as stock!
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 03-21-2007, 12:10 PM   #3
cdowns
cdowns's Avatar
i tried the poly mounts couldnt see in the mirrors threw them away after a few weeks and went to stock rubber
Old 03-21-2007, 12:19 PM   #4
agronomya
Junior Member
agronomya's Avatar
It depends on what you plan to use the truck for. If this is for your pro street '67 that is in your signature I would say go with poly. You want to eliminate as much flex as possible between the body and frame as you can so your suspension will not have to compensate for it. You will want to get maximum traction so a harder body mount will help with that.
Since it will be a pro street truck I'd also assume that it won't be daily driven so it shouldn't be that uncomfortable since you won't be dealing with it everyday. If it were to be a daily driver I'd go with rubber.
AA
They call me, "AA."
1969 Chevy LWB-SDPC 350, TH400, old farm truck
http://s123.photobucket.com/albums/o299/agronomya/
2006 Nissan Altima-For my 2000 miles a month
agronomya is offline   Reply With Quote
Old 03-21-2007, 12:21 PM   #5
Joe67
67 is sold
I've thought about his too.
Is it true that poly mounts will squeak while driving the truck?
I went with a rubber front end rebuild kit - that is all that I found available. I have a poly rear trailing arm bushing kit installed already.
My truck will see street duty only on nice days and some track duty if I'm lucky
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 03-21-2007, 01:13 PM   #6
smoknbarrels
Registered Mail
That would suck having a squeak down in there.
yea it is pro street, so it will not be on the road each day, just when it is nice. i was just thinking of going that way since our roads are pretty rough up here.. I was not sure how much give the poly's have. but if cdowns mirrors are shaking, it must me a pretty good sign of how stiff they are... hmm. still thinking about it..
Old 03-21-2007, 08:25 PM   #7
powell72
powell72's Avatar
Anytime I run Poly bushings I always put a coating of dielectric grease on them and have never had any squeak, including cab mounts(which I also didn't like the ride from them).
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 03-21-2007, 09:52 PM   #8
msgross
msgross's Avatar
I'm doing rubber mounts from LMC and poly spring bushings from Energy. Poly's claim is they deter flex so I would agree that it would stiffen the ride in the cab where a little flex is good.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-22-2007, 12:29 AM   #9
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
Race track or street? On the street I find poly not worth the benifet gained when going to the grocery store. To often we forget alot of the benefits gained using racing technology are lost or a pain in the a*# on the street.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-22-2007, 09:26 AM   #10
crazy longhorn
Fabricate till you "puke"
I run poly on my longhorn, & in my app it was needed. With a steel tilt nose, the 4 rubber bushings let the cab squirm too much( I never knew for sure where the clutch would letup!) the poly bushings took care of that problem, & are somewhat harsher than the rubber ones.....but not too bad IMO. I agree, if you are running @ the track, or dont run many miles on the street, go Poly......for a daily driver, you may be happier with rubber. L http://community.webshots.com/user/hotrodhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-22-2007, 10:57 AM   #11
72 Cheyenne402
72 Cheyenne402's Avatar
I have rubber I have heard it obsorbs the shock and are not as stiff as poly. Although I don't know.
1972 Cheyenne 402 LWB
2005 Silverado X-Cab 5.3L
2004 John Deere L120 20HP B&S
72 Cheyenne402 is offline   Reply With Quote
Old 03-22-2007, 01:31 PM   #12
Hart_Rod
Hart_Rod's Avatar
I used energy suspension's polyeurethane set on my 69 Burb and love them! I'm running air ride also, so maybe that helps, .
R
Hart_Rod is offline   Reply With Quote
Old 03-22-2007, 10:29 PM   #13
nvrforgotten52
nvrforgotten52's Avatar
i have the energy poly mounts on... i just drive on paved roads and sort but i dont mine them. if your coils are not still than they will absorb shock first anyways.
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 03-23-2007, 12:50 AM   #14
TONE
TONE's Avatar
AFTER SEEING WHAT THE ALL OF THE RUBBER LOOKED LIKE AFTER I DISMANTLED THE ENTIRE TRUCK, I WENT ALL POLY. THEN I PUT SHOCKS ON MY TRUCK AND PUT A SEAT IN THE CAB, THE POLY RIDES GREAT!
67 C 20 BOWTIE (IN PROGRESS)
- 1972 350 ENGINE
- MUNCIE SM 420
- 4.56 GEARS
TONE is offline   Reply With Quote
