Old 03-21-2007, 04:25 PM   #1
Duro5341
Duro5341's Avatar
LSD, and Posi options
Hey guys
In the next few months I will be in the market for a posi unit
The rear end in my truck is really starting to whine, and I am going to be doing a complete overhaul, and throwing in a posi
The truck will be mainly used for a Daily driver, occasional towing(3-4 times a year), winter driving.....very little off road use. I want something smooth, and automatic....no electronic stuff
I am torn between the clutch, and torsional gear type.......I like the idea of the torsional gear type, and it not wearing out, unlike the clutch type. I take really good care of my truck, and diffs are cleaned and drained every 50,000kms, so maintence is not an issue. I am just looking for something smooth, and easy to drive with
Just wondering what you guys have in, or have heard good/bad about
Any opinions are welcome....I have never had a Posi, and don't know **** about how they feel in the truck
Cameron
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 03-21-2007, 05:23 PM   #2
Duro5341
Duro5341's Avatar
Re: LSD, and Posi options
I was also looking at this
http://www.drivetrain.com/4x4.html
14 Bolt Custom Rearend Differential
But I have 2.76 gears, and they don't offer this....but it would be nice to upgrade to a 14 bolt, I know the 10 bolts are weak
Duro
Old 03-21-2007, 05:43 PM   #3
BaddBusa2005
BaddBusa2005's Avatar
i have an auburn pro in my 8.5 and I love it, but i only use my truck to spin tires and race around
1981 Custom Deeluxe SWB 5.3/4L60e 3.73 and Auburn. Mustang Dyno 265hp/258tq
BaddBusa2005 is offline   Reply With Quote
Old 03-22-2007, 01:00 PM   #4
BaddBusa2005
sorry guys I spoke too soon, it started giving my problems today
Old 03-22-2007, 02:54 AM   #5
84slopwaggin
84slopwaggin's Avatar
I have an Eaton but I've only had it for about a month. It feels the same as the stock open unit, but with the 3.42's it gets upto speed much sooner.
85 LWB Chevy 350/350stocker with Hooker headers dual Magnaflow mufflers upgraded rearend with Eaton Posi unit with 3.42 gears needs interior work(now my DD)
96 Silverado Xcab mild drop(SOLD).
84slopwaggin is offline   Reply With Quote
Old 03-22-2007, 11:19 AM   #6
boatpuller
boatpuller's Avatar
you guys watch that LSD..as a child of the sixties and seventies.i'm here to tell ya ,there's no future in it.
" Never look up a dead dogs butt."
boatpuller is offline   Reply With Quote
Old 03-22-2007, 11:28 AM   #7
martinkh
Unless you exceed tire size (>33"), I'd try the Detroit Tru-Trac. It is clutchless.
I just bought a set of 1 ton axles for my truck, the rear is a 14 bolt gov-loc, but am wary of it. For the 35" tires I will be running, I would prefer the Eaton posi.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift.
'77 400sbc, '82 axles, d60front, 14bolt rear.
Probably some 285/75/16 Toyo m/t's on my stock rims coming up.
martinkh is offline   Reply With Quote
Old 03-22-2007, 07:38 PM   #8
Duro5341
Duro5341's Avatar
I was looking at the Detroit Tru-trac one, and I am liking it
there is no special oil required, because it doesn't use clutchs
and there is nothing to wear out.........I like that
I am still debating up grading the rear-end, or keeping the 10 bolt....what do you guys think?. I don't burn tires, and will only be running a max of 32-33" tires in the future. No heavy off roading, or extreme towing.....just a car trailer 3 times a year
Duro
Old 03-22-2007, 11:42 PM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Duro
If you're talking about swapping to a 12bolt, then I would say I wouldn't waste my time. The 10 is plent strong for your intended purpose.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 03-24-2007, 08:22 AM   #10
Duro5341
Duro5341's Avatar
Sounds Good, i'll keep my 10 bolt......just give it a complete overhaul
I am going to replace
All bearings, seals, Tru Lock diff, new gears, and pinion shaft....anything I am forgetting?
Thanks for all your help guys
Duro
Old 03-22-2007, 01:07 PM   #11
84slopwaggin
What type of problems?
Old 03-22-2007, 11:14 PM   #12
BaddBusa2005
acceleration in a turn, the rear is popping. it is getting worse, and is about time to park it and get the gto out. I am thinking about going with the torsen.
Old 03-22-2007, 04:39 PM   #13
Captkaos
Captkaos's Avatar
If you are going with a LSD, I would go with the Eaton or the Torsion. I personally wouldn't recommend an Auburn, by design the eat their casing and explode.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 03-23-2007, 01:56 AM   #14
84slopwaggin
I've been told that when they start popping in the turns that it's time to add some LIMITED SLIP ADDITIVE. It's just a small bottle.
Old 03-23-2007, 10:09 PM   #15
Pyrotechnic
Pyrotechnic's Avatar
Sometimes you can feel them locking and unlocking in a turn if you're going just the right speed and just the right turning angle which is pretty normal. A loud pop though wouldn't be good.
Pyrotechnic is offline   Reply With Quote
