Old 03-22-2007, 01:10 AM   #1
ejkh87
Laying out a 69
Im wanting to lay out my 69 to the rockers without doing a body drop. I know I will have to either do a crossmember drop or a frame z. But I dont know which one ill need. Ive got an 8 inch notch in back so it will be no problem. Will I have to move the body mounts any? Thanks
ejkh87 is offline   Reply With Quote
Old 03-22-2007, 10:30 AM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Laying out a 69
Pretty sure you won't be able to get to the rockers unless you move the body mounts. The frame is below the pinch weld. I just got my sectioned x-member back from CaptKaos, but just that won't lay out the frame up front. I've got an 8" step notch out back so I'm set there. If I wanted to lay it out I'd need to Z it also. You could always lop off some of the frame under the cab and then box it in with square tubing.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-22-2007, 11:34 AM   #3
jlaird
jlaird's Avatar
Re: Laying out a 69
you guys must be running some small wheels because you wont come close to laying out on 20's with an 8" notch. I've got a 9" notch with a 29" tire and I'm about an 1" from laying out.
jlaird is offline   Reply With Quote
Old 03-22-2007, 07:18 PM   #4
cajundragger
Re: Laying out a 69
my brothers truck lays with an 8 inch notch and 20's.
if you have a 29 inch tall tire and your 1 inch from laying out, then on a 27 inch tall tire you'd be laid...
cajundragger is offline   Reply With Quote
Old 03-22-2007, 11:56 AM   #5
Slmd92DIME
Slmd92DIME's Avatar
Re: Laying out a 69
Could you just drop the cab mounts an inch and then be able to lay rocker not just pinch? I am doing a 4 inch z at the firewall then if I dropped the cab mounts an inch the z would have to be 5 inches at the radiator for everything to line back up. Thats what I was thinkin
Slmd92DIME is offline   Reply With Quote
Old 03-22-2007, 05:57 PM   #6
fastbagged68
fastbagged68's Avatar
Re: Laying out a 69
You can lay out with a dropped crossmember and taking out your body mounts. Shorten them up to about 3/16 thick. Thats what we did on our truck and it laid the rocker on 20's. The body will sit below the frame.
fastbagged68 is offline   Reply With Quote
Old 03-22-2007, 07:26 PM   #7
67Fleet
67Fleet's Avatar
Re: Laying out a 69
255/35/20 tire = 27" tall. That's what I'm runnin.
-Bret
Old 03-22-2007, 11:41 PM   #8
FnLow69
FnLow69's Avatar
Re: Laying out a 69
if you drop your body mounts 1 inch you should lay rockers thats what i did and with a 8 in notch 27 inches is about as tall as you can go.
FnLow69 is offline   Reply With Quote
