Old 03-23-2007, 05:17 PM   #1
stangalang
Help!!!! Starting Problem(@#$!)
Okay this is what is going on I have a new starter(Oriely"s), new alternater, fairly new battery, new ground wire, and pos wire all connections are tight. My battery has 700 cranking when I give it a jump it fires up or I put a freshly charge battery in, I put the voly meter on it while it is running and it reads a little over 14 then I let it run for least 5 mins and I shut it off and try to start it again and the starter drags and then clicks I have check everything I know to check am I missing something?
stangalang is offline   Reply With Quote
Old 03-23-2007, 05:25 PM   #2
Eyegore
What Hump?
Eyegore's Avatar
Re: Help!!!! Starting Problem(@#$!)
Check your ground not on the battery but on the motor - is it tight. Also check cables installed are they tight at the starter. If you want to check to see if its a start problem have someone turn the key to start and lightly tap the starter with the handle of hamer, if it engauges then you may have a bad starter. Also make sure your parking brake is on and your on good terms with whomever your using to start it while you climb underneath.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 03-23-2007, 07:07 PM   #3
us111
i haven't had the problem myself but i have seen talk on here where the starter's are getting hot due to no heatshield or to close to header's..when they get hot they will do what your's is,,try a search or hopefully someone with first hand knowledge will jump in..
us111 is offline   Reply With Quote
Old 03-23-2007, 08:24 PM   #4
Restrorob
The One And Only !!!
Restrorob's Avatar
I would jump it off and drive it to Oriel's and let them test everything with their machine since you have their parts on there.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 03-23-2007, 07:56 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
when you give it a jump it starts when its cold or it will start with a jump when hot? ( it isnt clear to me the way its written)
you may want to pull off the negative cable and check with a test light if there is a short draining the battery
the heat shield is one idea and also bad block ground
when you get in the truck cold do you have radio and fan horn and lights? how about when hot?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-23-2007, 08:37 PM   #6
krue
Designated A-hole!
krue's Avatar
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 03-23-2007, 08:55 PM   #7
stangalang
Man you guys were a big help the problem was a poor ground and the block was not grounded I did both and now she roaring again
Old 03-23-2007, 08:56 PM   #8
mySAVIOReigns
Active Member
mySAVIOReigns's Avatar
This is hilarious - I was about to post this same question. Thanks! lol
Website Here
-Stephen
1985 Chevy Silverado, 1/2 ton
mySAVIOReigns is offline   Reply With Quote
