Old 03-24-2007, 08:32 PM   #1
slepysal
slepysal's Avatar
rear spring help !!!
Ok so I am so pissed off right now!! How do yo take off the rear springs ????? My shop manual was useless, Remove springs.
Right now I have my shocks off, the trailing arms are on the ground and I am lost please help !!!!!!!
slepysal is offline   Reply With Quote
Old 03-24-2007, 09:41 PM   #2
slepysal
slepysal's Avatar
Re: rear spring help !!!
come on any one ????
Old 03-24-2007, 10:30 PM   #3
1restorick
1restorick's Avatar
Al, I just changed mine this week. Soak the bolts with penetrating oil and unbolt the lower spring bolts first. Your spring retainers have a built in nut so all you will need is a breaker bar or impact wrench to break the bolts free. After the lower bolts are out, lower the rearend completely. Then with a long extension you can get to the upper bolts. You will need to place a wrench inside the frame to hold the nuts from spinning If you place a floor jack under the differential you can change both springs at the same time. If your lucky the upper bolts will break from old age and corrosion and save you some time. Best of luck.
Rick
RED RUMBLE
1963 C10 Chevy Truck
Owned since 1984
1restorick is offline   Reply With Quote
Old 03-24-2007, 10:52 PM   #4
PrerunnerRob
PrerunnerRob's Avatar
With a torch!!!!
Seriously, lots of pentrating oil, lots of beating with a hammer to shake the rust loose, and a big wrench with a cheater bar. I let mine soak for week and ended up torching them off.
PrerunnerRob is offline   Reply With Quote
Old 03-24-2007, 11:18 PM   #5
slepysal
slepysal's Avatar
thanks, well I was able to get the bottom bolt loose and the top one off, on the right side. I Know I must be doing some thing wrong, becuse it shouldnt be this hard !!!
I gave up and thought I would just put things back the way they were, WRONG !!!!
I can't get the u bolts to line up to my axle!!! I swear I cant even get this thing back to the way it was !!!
ANy tips on putting things back to the way they were? Maybe I am jacking it up wrong ? HELP!!!
Old 03-25-2007, 10:45 PM   #6
PrerunnerRob
Undo your panhard bar if you havenet already, put a jack under the rear end, and slide it side to side until the u-bolts line up. that should work, and if not, undo the trailing arms until everything is loose and moveable. Good luck!
Old 03-25-2007, 10:48 PM   #7
slepysal
slepysal's Avatar
Thanks Prerunner !!! What about jackstand placment ?
