Old 03-24-2007, 11:35 PM   #1
bowtieride
Polishing a grille
Does anyone know a good way to polish the outer gille on a 69-72. If anyone knows of a good way i would like to know. Thanks
bowtieride is offline   Reply With Quote
Old 03-25-2007, 08:39 AM   #2
mnunn454
mnunn454's Avatar
Re: Polishing a grille
I'm facing the same thing in a month or two, once I'm done with the interior. This makes 2 of us looking for a good answer. Thx for posting.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 03-25-2007, 08:45 AM   #3
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Make that three!
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 03-25-2007, 08:58 AM   #4
chevydad
I had the same question,I took my grill to a custom car builder and asked what can I do.He took some 320 wet sandpaper and sanded about foot long section,then went to 600 wet,800 wet ,1000 wet.He then polished that section.It came out like new.I have about half the grill done,it's time consuming but the results are worth it. Bill
chevydad is offline   Reply With Quote
Old 03-25-2007, 08:56 AM   #5
msgross
msgross's Avatar
I've heard of WD-40 and 1000 steel wool for polishing/deoxidizing chrome/aluminum. That and a gallon of elbow grease!
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-25-2007, 09:59 AM   #6
The problem is the hard anodizing the factory used.Get through that and treat as any metal polishing.
Old 03-25-2007, 10:07 AM   #7
Huskerboy2
Autosol. Expensive, but works really well.
'72 Chevy Blazer
Huskerboy2 is offline   Reply With Quote
Old 03-25-2007, 10:47 AM   #8
[ol'Blue]
[ol'Blue]'s Avatar
where can you buy a gallon of elbow grease?
from mexico?
jk
[ol'Blue] is offline   Reply With Quote
Old 03-25-2007, 11:45 AM   #9
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
from mexico?
jk
Autosol and very, very fine Bull Wool Has worked well for me on tons of stuff.
Now a grill .... all of a sudden it just grew by about 10 feet!
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 03-25-2007, 12:51 PM   #10
BowTieOgre
I remember someone saying good things about WENOL.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-25-2007, 04:29 PM   #11
69ChevyLB
Active Member
69ChevyLB's Avatar
I think I saw a while back where you could use oven cleaner to remove the anodizing before trying to polish the aluminum parts.
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 03-25-2007, 04:35 PM   #12
1fast71
1fast71's Avatar
i just plain need a new outer grill anybody kno where i can buy one from?
for a 71
1fast71 is offline   Reply With Quote
Old 03-25-2007, 05:16 PM   #13
chevyman432003
eastwood says to use oven cleaner to take off the anodizing
chevyman432003 is offline   Reply With Quote
Old 03-25-2007, 06:37 PM   #14
Shane
Shane's Avatar
you can rub it with whatever you want ... cheap or expensive ... and it WON'T shine until you get the anodizing off it.
Oven cleaner to remove anodizing ... and then just about any decent metal polish will make it shine ... be prepared to polish fairly often now that the anodizing is gone, it will tarnish rather quickly.
Shane is offline   Reply With Quote
Old 03-25-2007, 06:49 PM   #15
RANDY COX
RANDY COX's Avatar
I think the steel grill that's Chrome plated looks really good,But as far as I know they don't make em for a 69-70 grill.When I get rich would like to buy new Grill.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-25-2007, 08:09 PM   #16
Wootdog
Wootdog's Avatar
Flitz metal polish will make it shine. Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 03-25-2007, 08:25 PM   #17
SacramentoJoe
Always Fixing Things
SacramentoJoe's Avatar
I used #0000 steel wool on my few sparse trim pieces. It won't make them new but will make them clean and presentable.
Just an Average Joe
‘68 GMC 307 3spd – My dad's original truck
310,000 miles
SacramentoJoe is offline   Reply With Quote
Old 03-25-2007, 08:26 PM   #18
racerman85
racerman85's Avatar
something i always do is use some soft scrub and a scotch bright pad before polishing... it smooths everything a little and makes it a nice, even color... just my opinion!
racerman85 is offline   Reply With Quote
Old 03-25-2007, 09:19 PM   #19
piecesparts
Parts and more parts
piecesparts's Avatar
The grilles are anodized and after y ou remove that, then you will be polishing forever. Just a thought to have in mind. With that covered, the process of taking wet and dry sand paper (starting with 600 grit and working your way to 2500 grit) and using wd-40 to keep the paper clean as you sand is a way to start. I finish up with a tub of Mother's aluminum polish (to remove sanding scratches) and then a touch of Mother's "billet Polish" for a mirror finish.
If you are really serious you can purchase some razor buffing pads for your die grinder and a buffing taper to hold them. Get some polishing compund sticks and go to it. It works great and takes less "Elbow Grease". Look at purchasing a couple bottles of "Metal Sealant" to seal the metal and keep water spots out of it.
