Old 03-26-2007, 10:07 AM   #1
SEVENTY1
SEVENTY1's Avatar
Where on engine is thermostast sensor?
Hi everyone, newbie here. Does anyone know where on the engine area I can find the thermostat sensor?. I have a 71 with the 350 V8.
Any help is greatly apreciated.
SEVENTY1 is offline   Reply With Quote
Old 03-26-2007, 10:12 AM   #2
bandit1
Re: Where on engine is thermostast sensor?
if you mean the temperature sender, its at the front of the block on the driver side near the number 2 spark plug
1969 GMC 910
1970 GMC 1500 custom
1972 yamaha 175
"Money is just like trucks you can never have enough"
bandit1 is offline   Reply With Quote
Old 03-26-2007, 10:13 AM   #3
stingray72
Red Headed Step Child
stingray72's Avatar
Mine's on the drivers side of the truck down on the block in between the first 2 spark plugs counting from the front of the truck
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 03-26-2007, 10:26 AM   #4
SEVENTY1
SEVENTY1's Avatar
Cool thanks.. My drive belt broke off last week, which caused my truck to overheat for a minute or two. After replacing the belt I drove my truck a few miles to make sure everything was fine, and I noticed that my thermo gauge was not working anymore. It was working fine before the belt broke off, so first thing that comes to mind is my sensor went bad or something. Has anyone ever had this problem?
Old 03-26-2007, 02:30 PM   #5
68Mike
68Mike's Avatar
If the belt broke, maybe it hit the sensor and knocked the wiring off. Could be something [I]really[I]simple...good luck
Mike
Currents:
'74 Cheyenne Super C30 Camper Special 3+3
aka "Sucia30"
Past:
'79 C10 BIG 10 (Sold)
69 CST LWB - Always a "Work in progress" true work truck (stolen)
05 GSXR 750 it has a pretty paint job _wrecked
72 SWB full frame restoration -sold!
71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold!
C10 Club 2012 Brothers Show Video
http://youtu.be/pUeV2vP7Wpo
68Mike is offline   Reply With Quote
Old 03-26-2007, 02:40 PM   #6
SEVENTY1
SEVENTY1's Avatar
That's what I'm thinking happended, I found one wire around the power steering reservoir, that looks like it's coming from the firewall, but just can't find where it connects to.
Old 03-26-2007, 03:04 PM   #7
blukangoo
Neighborhood Pickle Slinger
blukangoo's Avatar
Pictures say more than words.
I circled the temperature sender.
My C10 Diary
Our cars:
1966 Chevrolet Chevelle 396 - TH350
1968 Chevrolet C10/CST 327 TH400/375
1969 Corvette Stingray 350 - Muncie Manual Trans
1969 Chevrolet ElCamino 350 - TH400
1970 Cutlass Supreme Convertible - 350 Rocket - TH350
1973 Camaro LT - New Engine Done - TH350
1973 Corvette Convertible 454 - TH400
blukangoo is offline   Reply With Quote
Old 03-26-2007, 03:18 PM   #8
SEVENTY1
SEVENTY1's Avatar
Thanks, Blukangoo, I'll check it out as soon as I get home this afternoon.
Old 03-26-2007, 03:20 PM   #9
BowTieOgre
The temp sensor should be sticking out of the drivers side of your engine block and will look like this...
oops...too little too late...took me a few minutes to find a pic on the net. GL
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 03-26-2007, 04:08 PM   #10
blukangoo
blukangoo's Avatar
I have about 1500 pictures of my own right now and it grows every day.
When I get to putting everything back together, my Laptop is going to be my best friend and helper.
My C10 Diary
Our cars:
Old 03-26-2007, 03:20 PM   #11
Ole Blue 68
Ole Blue 68's Avatar
That sounds like it. I had the same problem once. My temp gauge went crazy and I almost had a heart attack till I realized that the wire had come undone and was touching the header.
Ole Blue 68 is offline   Reply With Quote
Old 03-26-2007, 04:01 PM   #12
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The wire should be green.
By the way, it's screwed into the head, not the block.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-26-2007, 04:24 PM   #13
BowTieOgre
Too right TX, im a little ill right now and the brain is a bit coudy.
Old 03-26-2007, 04:30 PM   #14
SEVENTY1
SEVENTY1's Avatar
Wow, thanks for all the help guys. I'll check it out tonight.
Old 03-26-2007, 04:31 PM   #15
rophle1
rophle1's Avatar
Sorry to threadjack, (hopefully since the original question was answered I won't be beaten), but I just did a rebuild and the guy who put the heads on put them on "backwards" he put the head with the temp sensor on the passenger side. There's a threaded whole on the drivers side for the sender, but we couldn't get the plug out (kept breaking sockets trying) so I decided to just leave it on the passenger side. Will this give me any problems other than looking like crap with the line running behind the engine?
1968 C10 Stepside
396 bored .030
TH400
rophle1 is offline   Reply With Quote
Old 03-26-2007, 04:36 PM   #16
72 68 andmore
I hope not cuz that is the same issue I had, you can put either head on either side....I goofed and left the empty hole for the send at the back hole on the passenger side.........seems to work okay. I remember my 79 chevy van was like that so I guess I should be okay
72 68 andmore is offline   Reply With Quote
Old 03-26-2007, 04:46 PM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It'll be fine
Old 03-27-2007, 09:03 AM   #18
SEVENTY1
SEVENTY1's Avatar
I found the sensor last night, and there is nothing hooked up to it. The only green wire that I found has an flat end connection that looks like it wont fit. It started raining last night so I did'nt have time to mess with it. Does anyone know what the green wire end connection looks like?
Old 03-27-2007, 09:54 AM   #19
Tx Firefighter
That's the wire. It doesn't plug straight on, it slides on from the side. It's a real funny connector. Notice the temp sender has a tit on it that looks like the head of anail rather than a spade like you might expect.
Old 03-27-2007, 10:40 AM   #20
SEVENTY1
SEVENTY1's Avatar
I'll try that during my lunch break Thanks.
Old 03-27-2007, 10:45 AM   #21
blukangoo
blukangoo's Avatar
just went through my couple of pics again and found this one.
Not too good because I had to zoom in.
Just like Tx said, it slides on to the side of the tip.
My C10 Diary
Our cars:
Old 03-27-2007, 11:07 AM   #22
SEVENTY1
SEVENTY1's Avatar
Thanks for all the help and pics guys . I tried it and now my gauge is working.
SEVENTY1
Old 03-27-2007, 09:02 PM   #23
dwaite72lnghrn
rophle1, You could always buy another sender and and put in the correct location. That way your wiring harness would still match up.
I have a BBC and have the OEM in the passenger side like factory and an aftermarket in the driverside head.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 03-28-2007, 01:12 AM   #24
stsalvage
Scrapper 1
stsalvage's Avatar
All i say is go buy the edalbrock intake and have it on the Intake the one on the side of the engine is nice but GM dose not like them there they like them where the inlet is on the intake cus the wire dose not get as hot or it dose not get full of oil or greese just look its a better set up and better off getting the engine wire harness cost you 139.00 but its well worth the truble just look how nice it stays out of the way and look where the ram hon it its just too close and to much heat
stsalvage is offline   Reply With Quote
Old 03-28-2007, 01:32 AM   #25
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
When I bought my truck the original engine was gone and replac with an later engine.(It had a long nose water pump and the dip stick was on the right side). Well I believe the temp. sender was on the intake manifold close to the carb, I dont think I had one on the side of the head. I put an edelbrock intake on the motor so I'm going to do what stsalvage did and put it on the intake.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
