Frame Boxing Question
I am getting ready to box my frame rails and just want to make sure I am planning correctly. I was going to cut the steel to the size of the inside of the frame rails, grind the edges at an angle, then weld them smooth to the inner edges of the frame. Does this sound correct?
1972 Blazer body...need to get a thread started for the rest of the story |
Big Block Short Bed Stepside
Re: Frame Boxing Question
Are you angling it from top to bottom. Or are you tring to make it square with the bottom having a lip. Use long pieces of card board to make templets. Weld spot to the corner. Weld from bottem to top front to back little welds at a time at 35-45 degrees. Keep the metel from getting waves. Bevel the plates at 45 at top and sides for the butt weld. Hope that helps.
I'm not trying to be a smart a$$, but why would you want to box the frame?? Really an honest question.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) ![]() 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again ![]() 2002 Tarus (my wife loves that car) |
#4 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
looks and for strength thats what I'am doing
more for strength!!
69 4wd V6 20k orig miles!! ![]() 05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored. ![]() 01 rcsb chevy 2wd 6bt cummins :devil:> build xtremediesel.com |
Thanx Simon. I forgot about the fact the lower lip is wider than the top. I am planning on making the inner plate straight up and down. So I will have to work on that.
With the open c chanels and even with the roll cage the frame will still twist up a little. Alot of the old hot rodder weld up the frame to give it a nice clean look.
Active Member
Ask Mike Rowe on the Ferd commercial. Stronger frame. Not necessary for a daily driver, but if you are racing or pulling max loads then it is besides smoothing the frame for a show truck. That is the biggest reasons to do it.
Sonny New Project: 67 Small window SWB 2006 Crew Cab Silverado LT ![]() ![]() |
Junior Member
For the killer looks factor, how 'bout building a new frame entirely, from 2x5 or 2x6 rectangle tube...? Helluva fun project, I think. And from the condition of the frame on my truck....it'd be easier and faster to start over than to box it (massive infestation of rust) A boxed frame would be slick though. Anyhooo, my $0.02 worth of
Ryan Metal Massacre Fabrication New Projects: -New radiator core supports, steel and stainless -Aluminum radiators -Aluminum dual electric fan shrouds '69 C-20 Custom '69 Nova...BIG BBC soon '72 3-door 'Burb...in a few '94 K2500 454 'Burb |
