Old 03-27-2007, 06:06 PM   #1
iluvmy72
oil pressure help
OK...I posted this on the 88-98 section of the site and the bums gave no advice.......So i'm posting this question to the always reliable 67-72 area......Problem I've been noticing the last couple of weeks the smell of burning oil on the exterior of the engine area. I look down in front of the engine where the arms and joints are, and I can see newley wet caked on oil covering them so it looks as though a small leak is somewhere in the front area. And yesterday while driving I notice my oil pressure way low so like a dumbass I freaked and put 3 quarts of oil in the thing without checking the dipstick. Now it's way over and I've have to remove some. It seems to me I have a pressure leak somewhere....but where should I look first? and why is the pressure showing so low if it's so high on the dipstick?.....I have a 94 4X4 with a 454 and towe package.
iluvmy72 is offline   Reply With Quote
Old 03-27-2007, 06:13 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: oil pressure help
Check the oil pressure sending unit gor leaks.
Also, some big block trucks of that year had an external oil cooler in the front with two lines running to it. Check them for leaks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-27-2007, 06:22 PM   #3
bryanw1968
bryanw1968's Avatar
Check to make sure that your PCV valve is working properly. If not, you will build up blow by pressure and blow it right out of the gaskets. Did this just start?
Good luck,
B
bryanw1968 is offline   Reply With Quote
Old 03-28-2007, 01:45 PM   #4
iluvmy72
yeah this just started
Old 03-27-2007, 06:59 PM   #5
sodak69c10
sodak69c10's Avatar
hello, i had a problem kinda of like that with low oil pressure when i first started it it had great pressure but at temp it only ran like 20 lbs at idle i put a pump on it solved the prob, but it sounds like it could be coming from the front crank seal, isn't powersteering fuild is it?
sodak69c10 is offline   Reply With Quote
Old 03-28-2007, 03:47 PM   #6
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
No relation between oil pressure and oil level. RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
