03-30-2007, 04:53 PM | #1 |
Tach kit?
Thinking about buying a tach kit from lmc, its 89 dollars wit everything to hook it up. How much work is it to do. Any one buy the kit, is it junk.
It cant be to hard to hook up i think,but thats what I thought when I changed out the track on my snowmobile. Thanks. |
03-30-2007, 07:13 PM | #2 |
Like a Rock!
Re: Tach kit?
For $89 you only get the tach head. You still need harness, lense, front and rear tins!
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! |
03-30-2007, 11:20 PM | #3 |
Re: Tach kit?
http://www.lmctruck.com/icatalog/cb/0051.asp
I hate to be cocky but... It is a whole kit Listed in top right corner including a front tin and wiring harness. I guess |
03-30-2007, 11:27 PM | #4 |
Re: Tach kit?
double check the item number #24 is the kit for $349.00
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
03-30-2007, 11:30 PM | #5 |
Re: Tach kit?
I read it as $349 for the kit.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
03-30-2007, 11:36 PM | #6 |
Re: Tach kit?
Sorry my bad.
I miss intrpreted my outdated catalog It had a Tach for 89 dollars know it is 74 I can live with out a stock tach for that much. |
03-31-2007, 10:27 AM | #7 |
Re: Tach kit?
Dang, you can get a whole new dash with all gages elsewhere for around $550!! Not stock tho.
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
03-31-2007, 11:51 AM | #8 |
Junior Member
Re: Tach kit?
I have found for my needs a Sunpro Super Tach II works just fine mounted on the steering column in my daily driver, 71 C-10.
My son has had a Sunpro tach in his 70 C-10 for many years and it has worked well no matter what engine he had in it at the time. If I were doing a complete restore or show type truck I would like the in-dash setup. Danny - SEMO |
03-31-2007, 03:15 PM | #9 |
"Trucks with Class"
Re: Tach kit?
You can buy that complete tach kit for $250 or less...OR
Contact byrd on the board and he will build you a beautiful tach dash! |
