Old 03-31-2007, 05:22 PM   #1
e rock
So how would you pull the motor?
I'm not on here much, but a few of you may remember the drama a few months ago when my 71 K20 was stolen and then I got it back after it was stolen from the police impound... Anyway, when it was stolen, the speedo wasn't hooked up so I have no idea how much it was driven for the month it was gone. Also, when I got it back, it was low on oil. I filled it up and didn't notice any problems, but didn't drive it much since I was still in the process of fixing a few things to make it more secure and more commute-worthy. Well, a couple weeks ago, I was feeling more confident in everything so I was headed to work on the highway and heard a noise that sounded like the fan getting into the radiator. I was on a narrow overpass, so I was preparing to pull off as soon as there was a shoulder, but with about 50 feet to go, the noise got a lot worse and there was steam/smoke all over the place. I killed the motor, pulled over and popped the hood still expecting to see a thrashed rad. Nope - rad, fan, and water pump were all fine. Then I noticed that I had oil leaking onto the ground. So I crawled under and found this:
Then I followed the oil trail back a hundred feet and found these:
Apparently the oxygen-waster that stole my truck did more damage than I thought.
Anyway. I've been on a well-needed vacation for the past 1-1/2 weeks, but now I'm home and get to deal with this crap. I have a donor motor lined up from a running and driving car. I've done plenty of motor swaps, so I'm not really concerned with the specifics, but rather looking for wisdom on which way to swap it. Should I pull the tranny and tcase (sm465/np205) with it or leave them in place and stab the tranny in the truck? Is there even room to do that without removing the crossmember? The truck is only stock height, but that's still a pretty good lift for a cherrypicker especially with an extra 500 pounds hanging on the back. Any thoughts?
e rock is offline   Reply With Quote
Old 03-31-2007, 05:52 PM   #2
kwmech
Re: So how would you pull the motor?
Just leave the trans/t-case assy in the truck and separate at the bell.
Old 03-31-2007, 06:02 PM   #3
centsless
sufficiently talented fool
centsless's Avatar
I agree with kwmech, Just pull the motor. Leave the trans and transfer case in the truck.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 03-31-2007, 06:15 PM   #4
e rock
Thanks. That was my first inclination, but wasn't sure if there was enough room to clear the input shaft without running into issues with the motor mounts or whatever else.
Old 03-31-2007, 06:17 PM   #5
RedZ71
Junior Member
RedZ71's Avatar
ill say that guy damaged your motor!! look at all the popcorn kernels he poured in there!!
Jonathan
2001 ECSB Silverado Z71
1971 LB C10 Custom
www.z71silverado.com
RedZ71 is offline   Reply With Quote
Old 03-31-2007, 06:22 PM   #6
e rock
Those are the bud caps from the blossoming tree in front of my house on the wet sidewalk.
Old 03-31-2007, 06:17 PM   #7
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
6 bolts on the bellhousing, sending unit wires, unbolt the manifolds,oil pressure gauge tube. Fuel lines, throttle linkage, pop the fan off and take the radiator out. Take off the two motor mount bolts, then yank the motor.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 03-31-2007, 08:56 PM   #8
2nd_wnd
2nd_wnd's Avatar
You might consider if height is a problem. you can either find some small tires to put on it or let the air out of them, just not enough that the tire comes of the bead.
I agree with just pulling motor thats what I just finished doing on my gmc.
Try to find, if you dont already have one, a plate to mount on intake to pull with it will allow you to not be as high as a chain or leveler
72 LWB
2nd_wnd is offline   Reply With Quote
Old 03-31-2007, 10:44 PM   #9
krue
Designated A-hole!
krue's Avatar
You've got my kind of luck.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
