03-31-2007, 05:23 PM | #1 |
z'ing and bagging a 64 Longbed, what would be better?
Ive got a 64 Longbed Im going to start gathering parts to z/notch and bag. Ive got a buddy with a pair of McGaughys 67-70 2.5 drop spindles I can pick up for cheap. What would be better here. I know where to find a whole crossmember/a-arms/ect for a 67-70. I can also pick up a newer 85 model front, and buy drop spindles for it. Which would be better? Did they drasticly change the caster/camber values in the 80s trucks? Would this be a better handling setup? This truck will eventually have a motor weighing right around a BBC, and the truck will be used for car hauling. Would the older stuff be up to the task? Or should I ditch the stock stuff/6lug and go with the newer 80s stuff with 5 lug?
And after all is said and done, when I take it to get aligned, what specs should they align it to. Any special stuff needed to be changed for a lowered truck like this? Thanks for all your help guys. Kyle Last edited by ElkyRacer; 03-31-2007 at 05:23 PM. |
04-01-2007, 07:29 PM | #2 |
Re: z'ing and bagging a 64 Longbed, what would be better?
Anyone? Anyone? Bueller? Bueller?
04-02-2007, 01:30 AM | #3 |
I would recommend going with the later model front end and components. The parts are more readily available, and I believe the control arms and bushings to be a better design. Have the alignment shop use the specs for the model year of the front end you use.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-02-2007, 11:40 PM | #4 |
Cool thanks! Has anyone used the later model 3/4 ton stuff? Is it still a sorta bolt in deal too? Im planning on boxing the frame, as 900lbs sitting on the front end is going to be a strain I think. Should I step up in bag size to compensate for the weight? Im totaly new to this bag stuff so bear with me!
Kyle |
