04-01-2007, 01:02 AM | #1 |
Please Help Me =(
Ok, so my 87 swb has a new issue... when you first start it up there is a squeek like a belt and only does it when u rev up, could be the belt? when you put into reverse it takes like 5-10 seconds then u can feel it lightly kick in, my truck also does the squeek if i hammer the throttle and it squeeks right before it shifts into the next gear or if i go 55mph or faster it will untill i slow down... i was told my torque converter may be going bad? is the squeek a belt? sometimes it feels as if my truck is bogging down and then it will catch up with its self and go.... whats the deal? its a 305 tbi with a th400 trans
1973 Chevrolet C20 (Under Construction) |
04-01-2007, 10:37 AM | #2 |
Re: Please Help Me =(
It almost sounds like you have two seperate problems. The squeek at start up and revving sounds like a belt slipping. Are your belts glazed over? And the second problem sounds allot like low/bad fluid. Also there is a vaccum line to the tranny modulator from the intake make sure it is connected and not split. I would drop the pan and fully service the tranny before going right to the converter.
Ed U.S. Coast Guard BMC (retired) |
04-01-2007, 10:40 AM | #3 |
Robert Olson Transport
if the fluid is not cherry red and smells burnt id leave the trans alone and budget a rebuild.. if its low id add to it but to service a trans with burnt clutches only hastens its demise. I agree with the belt issue either tighten up the slack or change them and if the pulleys are real glossy id use a little sandpaper on em to get the shine off and make the belt grip better
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-01-2007, 10:54 AM | #4 |
Oh,you can't buy that new
A converter squeaking??? I don't think so.
listen good to the alternator with a long screwdriver while someone else taps the throttle. Bearings go bad in those alternators all the time. crossy
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
04-01-2007, 12:38 PM | #5 |
Junior Member
HotRod73,
? Could it be a bad A.I.R. pump causing the belt to slip and squeal?
Have fun, Don |
04-02-2007, 08:45 AM | #6 |
what is the a.i.r. pump located and how do i tell?
