Old 04-02-2007, 10:27 AM   #1
cowdoc
Need pics of rear e-brake cable attachments
Hi folks,
Truck must be missing something, there is nothing for the rear e-brake cable housing to mount into, or I may have gotten the wrong cables.
The cables end partway up the trailing arms, and will attach fine to the intermediate cable (which might also be wrong but I doubt it.)
Looking in my chassis service manual it shows a bracket on the trailing arm which is missing. Doesn't look like there's any hole to bolt it in either. Did some cables end at the hole in the frame? Seems like having the end of the cable being mobile would allow up-down motion of the suspension to apply the brakes by changing the effective length of the cables???
thanks for any help.
Jacob
'67 C20 fleet/wood; 250/SM420, coil rear...it's a work truck
cowdoc is offline   Reply With Quote
Old 04-02-2007, 10:28 AM   #2
cowdoc
Re: Need pics of rear e-brake cable attachments
Sorry, forgot to add it's an Eaton rear (HO52).
Jacob
Old 04-02-2007, 11:33 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There are brackets spot welded to the outside of the trailing arms about 1/2 way back down them.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-02-2007, 11:46 AM   #4
rlm316
rlm316's Avatar
Check the inside of the arm. If they were replaced they may have been reversed, and that would put the brackets on the inside.
rlm316 is offline   Reply With Quote
Old 04-02-2007, 04:31 PM   #5
cowdoc
OK then, at some point in the past the truck lost the brackets. There are some spots that look like old spot-welds, just no bolt holes.
Does anyone make these brackets, or do I get to fab them/have them fabbed?
Jacob
Old 04-02-2007, 07:54 PM   #6
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
I don't know, but when I redid my ebrakes, I took a lot of pictures, so this may help:
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 04-03-2007, 01:06 PM   #7
cowdoc
Thanks much for the pics OldGold. That's kinda what I had in mind for the brackets to look like; helps to see where on the arm they should mount.
Guess I might be able to scrounge something from a junkyard too, but looks like a pretty easy cut-n-weld job...have to see how much it'd cost.
Jacob
Old 04-03-2007, 09:05 PM   #8
stsalvage
Scrapper 1
stsalvage's Avatar
hello here are some more brake pics hope they help
stsalvage is offline   Reply With Quote
