Old 04-03-2007, 03:39 PM   #1
Orange
Licensed to Thrill!
Orange's Avatar
Leaf rear vs. Coil Rear
What's the advantages of either vs. the disadvantages of the other.
I currently have a leaf rear end, and see a lot of people swapping to a coil rear and I don't really understand why.
When you don't know, ask.
I know leaf's are good for hauling, but I am not into a lot of heavy hauling.
I am not going super low, so that's not a big deal. But I do want something that rides and handles nice, so what's going to be my best and most affordable route?
Thanks.
DLB
1971 GMC.Lowered. Overdrive. Orange.
Krue's excellent FAQ Index.
Orange is offline   Reply With Quote
Old 04-03-2007, 05:31 PM   #2
raggedjim
raggedjim's Avatar
Re: Leaf rear vs. Coil Rear
In my opinion, it is easier to drop a truck with trailing arms and coils.
Leaf springs are supposed to haul better (I don't haul anything, so I can't say for sure)
I like the handling of the trailing arms, whether they are stock or lowered.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 04-03-2007, 08:57 PM   #3
rodnok1
rodnok1's Avatar
I wouldn't go to all the trouble of swapping from one to another just to lower it some. You can lower quite a bit with leafs, flipping the axle even for getting it lower. Coil trucks do handle better and actually seem to handle heavier loads better, but leafs are easier and cheaper to maintain.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 04-04-2007, 03:40 PM   #4
Orange
Licensed to Thrill!
Orange's Avatar
That's the key...
I have been driving a 4th Gen. Camaro for the past 6 years while my truck rested in the garage pretty much. Needless to say, I wouldn't mind improving it a little in the area of handling.
DLB
Old 04-07-2007, 06:17 PM   #5
72 cheyenne pdx
72 cheyenne pdx's Avatar
The only resaon I can see on swapping Leaf to Trailing Arms is if you were going to bag the truck. If you just want a lower stance, I would keep the leaf set up.
72 cheyenne pdx is offline   Reply With Quote
Old 04-07-2007, 07:43 PM   #6
Rokcrln
Rokcrln's Avatar
For some other ideas check "LFD's Low buck truck build". I have done the rear flip with my leafs and have now added bags for hauling. It is lowered 4.5/6-7. I have not finished it yet due to customer builds but it will be back on the road in a wek or two.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 04-12-2007, 12:20 AM   #7
Redden05
Redden05's Avatar
Where would be the best place to get drop leaf springs?
Redden05 is offline   Reply With Quote
Old 04-12-2007, 01:51 PM   #8
jkaylor68gmc
jkaylor68gmc's Avatar
Is that you dalton, if so go with the trailing arms, you will be a ton happier. You know that is what is under the back of the yellow truck.
jkaylor68gmc is offline   Reply With Quote
Old 04-12-2007, 02:36 PM   #9
68c-10
I can't speak for a short box ride, but my 68 long bed with leafs rides and handles very nice. My dad says that it rides better than a caddy and that with the bed empty. I like the leafs for the easy exaust routing and how simple it is. My truck is stock in the back except for removing the extra over load springs that were on top.
68 Chevy C-10 custom, 350,4bbl, serp belt swap, th400, 5 lug disk conversion, added honda seats and factory tach.
71 Gremlin X, 360, t-5, 8 3/4 rear, and dodge dakota seats.
82 Spirit, 4.0,ax-15, 8.8 rear and sti bucket seats
68c-10 is offline   Reply With Quote
