04-04-2007, 01:57 PM | #1 |
Sandblasters?
I'm in the market for a sandblaster for cleaning lots of small parts and cab and bed floors.
Does anybody have advise on a good ones?? I have a large shop compressor to support it, just looking for some advise and input from current users........ Thanks
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread Last edited by Mt Man Chad; 04-04-2007 at 01:57 PM. |
04-04-2007, 02:15 PM | #2 |
Re: Sandblasters?
I can't give you advice on Mfg's of sandblasters but I can give some feed back from 1st hand expirience. I have a small pressure pot ( 20 gal ) sand blaster, 25 cfm compressor and an air dryer. I blasted 2 frames last yr. and ea. took me about 6-8 hrs to complete. I chewed up 2 ball valves and 2 blasting guns. So the inexpensive ( Harbor Frieght ) units are cheap junk. You'll also need a good blasting hood and respirator to protect yourself. A suppied air hood would be best and would help keep you cool when it's hot out. I would say that this set-up is good for occasional small job, fender, gate, door, but if you want to do larger items hire a professional. I'll be doing 3 frames soon and a professional will be hired.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 04-04-2007 at 02:15 PM. |
04-04-2007, 02:42 PM | #3 |
Re: Sandblasters?
www.tptools.com is where i got my cabinet from american made in the usa have had no problems with stuff wearing out from substandard parts have had it close to 10years// you must have excellent DRYYY AIR for it to work excellent
04-04-2007, 04:05 PM | #4 | |
Self-proclaimed LED man
Re: Sandblasters?
Justin
My LED Website My Photobucket Album of LED's Ask me about hand-made custom L.E.D brake and reverse lights. <- LINK I also do LED: -Third Brake/Cargo -Brake (truck and burb) -Reverse (truck and burb) -67-68 Front Turn Signals -69-70 Front Turn Signals -71-72 Front Turn Signals -GMC Front Turn Signals I can also do custom lights for other vehicles....i did a set for a AMC Gremlin once Norwood Survivor |
04-04-2007, 04:27 PM | #5 |
Re: Sandblasters?
Blasting is nasty work , if you can avoid it DO
I have a cabinet and even the small stuff is tedious work there are so many ways to strip I'd do your homework. I've tried to be real careful and even small jobs with the cabinet sand particles get everywhere I like my cabinet but I'll never do large stuff again (outside the cabinet) If it were me in need blast the bare minimum needed and grind the rest the sand will haunt you ! good luck and have fun whatever you do
"I feel the need for speed!"... as soon as I am done with my nap. |
04-04-2007, 04:32 PM | #6 |
Active Member
Re: Sandblasters?
Here's another vote for tptools. I did alot of research when I bought mine, and I have no regrets, the quality is top notch and I've had no problems whatsoever.
71 Blazer CST 72 K20 Capt USAF |
04-04-2007, 02:44 PM | #7 |
Re: Sandblasters?
I built my own based on a design I saw at Harbor Freight. I just bought the replacement gloves and mounted them up. I also got the lexan for the window and light cover out of the "scrap" pile at Applied Plastics for free.
It cost me less than half the price and I built it to size. Like this only about 200% larger:
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
04-04-2007, 06:33 PM | #8 |
Re: Sandblasters?
We got one of the cheap pressurized tanks from Harbor Freight. It works ok as long as you have a large compressor. If you have a little one, you will be sitting around waiting for air all the time. The valves are real cheap on it though. They stop working real soon after a few uses. It gets the job done though. The best thing we did when we blasted my truck frame and lots of parts was to rent a big diesel compressor and huge blaster with a monster line about the size of a fire hose. That thing was mean. That took some work to hang on to the hose while working, but you can just make a quick pass and there was bare metal showing. It went through sand fast.
