04-07-2007, 11:33 AM | #1 |
12 Bolt carrier size?
I have an open 12 bolt on my 70 w/373 gears. Plan on installing a posi and was wondering if the 373 gearing will except a 2 or 3 series carrier or either one?
1997 GMC Sierra Ext 1965 Mustang |
04-07-2007, 11:51 AM | #2 |
Re: 12 Bolt carrier size?
You can get 3.73's in a 3 or 4 series carrier. Our trucks didn't have any 2 series gearsets.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
04-07-2007, 03:15 PM | #3 |
How about 3.42s?Which carrier is required for that ratio?
04-07-2007, 03:20 PM | #4 |
So either a 3 or 4 series will work with that gearing?
04-07-2007, 03:25 PM | #5 |
3.73 and up is a 4 series but I think I heard you could put 3.73 gears in a 3 series as long as you added some sort of spacer. Unless you ever plan on going with a 3.08 or something later on just get a 4 series and call it good.
1986 C10 - LWB, 305/700r4, posi, vortec heads |
04-07-2007, 03:32 PM | #6 |
if I remember correctly, a series 3 does 3,07/08 to 3.73 & a series 4 starts at 3.73 & goes up to 4.56
04-07-2007, 04:20 PM | #7 | |
When I bought my Eaton posi and new 3.73 R&P I had to make the tough choice. I opted for performance over mileage and went with the 3.73 over the 3.42, and therefore had to go with the 4-series carrier. Since upgrading to the 454, now I wish I'd gone with the 3.42s and 3 series carrier. You can run a 4 series R&P on a 3 series carrier, if you use a ring gear spacer or buy a "thick" style ring gear. This arrangement should be fine for stock/normal use. Check with the R&P sellers if you're still in doubt.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
